Edelbrock vac. sec questions
Old Jan 13, 2002 | 05:51 PM
Tominator's Avatar
Tominator
Default Edelbrock vac. sec questions
Not 100% sure it's kicking in, here's what I did;
1) put it in low (1) and floor it and run to 6200 RPM and at 2700 RPM it feels like it kits in, can it kick in this late? Can you run to 6200 RPM with only the primaries kicked in?:confused:
2) had two different people with me and did it several times each and they thought it kick in but nobody was sure. The thing is it's so incrediable and such adrenaline rush going on that I'm not sure. :eek:
Old Jan 13, 2002 | 10:09 PM
Tominator's Avatar
Tominator
Default Re: Edelbrock vac. sec questions (Tominator)
TTT
Old Jan 14, 2002 | 08:51 AM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
1) put it in low (1) and floor it and run to 6200 RPM and at 2700 RPM it feels like it kits in, can it kick in this late? I'd say mine is similar
Can you run to 6200 RPM with only the primaries kicked in?:confused: probably not, the engine needs a lot more gas at that rpm
I think the only way to really do it by feel is to tape or wire the secondary vacuum plate shut, and then go through your routine. You'll feel a difference when your rpm's climb and it lags on you
To Edelbrock vac. sec questions
