thermo fan sensor question
Old Nov 13, 2008 | 01:56 AM
gingerbreadman1977's Avatar
gingerbreadman1977
dont you think any temp higher than 200 is not really healthy and certainly 210 + for prolonged periods is causing damage ? .....and dwnnchs your right i cant complain about the reliability of a clutch fan , they are bulletproof but i just hate all that clutter with a shroud and the rest of it so i dont go that way.in the near future when my radiator comes back from getting a new core ill make a decision. ill either go in the direction of a 175 thermostat as suggested , or a manual switch like whats in the vet .not many places to put a sensor on the downstram side of a radiator. thanks everyone
Old Nov 13, 2008 | 08:02 AM
...Roger...'s Avatar
...Roger...
Since your going to have the rad out could your repair place install a fitting in place of the drain or close to it that would accept your sensor? That would give you temp sensing where you need it.
(Personally I never use the drain,I use a siphon to drain the rad.)
