Fuel Injector cleaner?
Old Nov 11, 2008 | 09:36 AM
flynhi's Avatar
flynhi
Default Fuel Injector cleaner?
What's the consensus on the best/strongest fuel injector cleaner that I can run through my gas tank?
Thanks.
Old Nov 11, 2008 | 10:10 AM
moosie982's Avatar
moosie982
I have excellent results with "TECHRON" . Peace,,, Moosie
Old Nov 11, 2008 | 10:31 AM
1yy07's Avatar
1yy07
Default fuel cleaner
SEA FOAM
Old Nov 11, 2008 | 10:46 AM
1972warship's Avatar
1972warship
Thanks.
I'm in full agreement with these guys.
Sea Foam is probably the strongest, but Techron is also very good.
I usually just use Techron.
Old Nov 11, 2008 | 04:53 PM
Roughrider's Avatar
Roughrider
Originally Posted by 1yy07
SEA FOAM
Use Seafoam...pour it slowly down the brake booster vacuum line and it will do two things...clean out the induction system and smoke up the neighborhood. It may also make necessary a change in spark plugs as all kinds of crap will be flying around the combustion chambers.
Adding to the gas tank is good, but directly through the induction system is faster and more effective. It's good stuff.
Old Nov 11, 2008 | 08:08 PM
baxsom's Avatar
baxsom
i love sea foam.
i used it on my 72 when i first got it, smoked up the entire neighborhood.
when i changed the oil, it smelled horrible.
Old Nov 11, 2008 | 08:40 PM
noonie's Avatar
noonie
How would that clean out the fuel injectors???
Old Nov 11, 2008 | 10:49 PM
flynhi's Avatar
flynhi
Thanks for all the comments.
W.
To Fuel Injector cleaner?
