Third Brake Light for C3
I was perusing the Harbor Freight flyer the other day and saw that they have 12V 9.5” LED strips for sale. They are advertised as accent lighting and come in blue or red. I thought that if the red one was small enough, it wouldn’t be much trouble to wire it into the brake system.
So next time I was near the store, I swung in and looked at it. It’s about ¼” tall, and maybe ½” deep, by 9.5” long. I figured for $8, I couldn’t go wrong.
Here’s a picture & a link:
http://www.harborfreight.com/cpi/cta...emnumber=98408
I did a dry fit before disassembling anything, and it slid right into the space between the T-top interior trim piece and the rear window. Very unobtrusive.
So, on to removing the interior pieces. I decided to run the wire along the T-top center bar, then along the top of the windshield & down the driver side pillar. Then I could tie right into the plug at the brake pedal switch.
Here are some pictures of the in progress. Unfortunately, the car (Fiberglass) is very thin at the place I want to mount the light, so I couldn’t use the included mounting clips – the screws would come through the top of the car… So I just put it up with some clear adhesive caulk, and held it in place with masking tape until it cured. I figured this would still be removable if needed with a minimum of fuss.
First I used some 2 conductor speaker wire to run all the way down to the brake pedal, but then wasn’t sure where to ground the thing. Then I realized I’d passed several screws that went right into the birdcage (grounded) on the way down, so I put a spade terminal on the negative lead from the light strip & attached it to the nearest screw. In this case, it was one above the windshield that holds on the silver trim piece. Then I ran a single wire from the positive lead, and soldered it to the plug that runs the brake lights (The white wire is the power for the brake light circuit).
The light strip only draws ~100mA, and the brake lights draw ~4.2A, so I didn’t feel real bad about piggy backing it on the same circuit/fuse.
Works great, looks great. I was a little concerned about the brightness, but it matches pretty well with the other brake lights – maybe just a hair dimmer, but definitely noticeable.
I’m really happy with how it turned out. In the dark, you do get some reflection off the rear deck, but it’s not too bad, I might try to black out the bottom of the light to reduce the amount of red light coming into the car, but it really hasn’t bothered me yet, so I may not get around to it.
Another project on the research list is how to make the front parking lights turn on with the ignition – also like the C5s. It gives me something to do in the evenings…
Just thought I’d share!
Dan
rcread, seriously? Only 4.3%? I'm surprised. If you want another eye opener just read their report on airbags...cliffs notes version, wear a seat belt. You are more safe at a wider range of speeds and there is no data on seat belts killing people but documented cases of airbags doing so.
Roger
Here's some reasons I think C3's, and other Corvettes, might be susceptible to being rear ended.
1) Pushers. Sometimes driving I've had people right on my tail. I think they are just trying to goad me into speeding up. Sort of like someone driving a dorky car wants to let me know that they want to drive faster than me.
2) Railroad tracks, pot holes. I've got really stiff springs and a lot of body flex. I slow down for rough sections in the road much moreso than when driving my DD. So, putting on the brakes unexpectedly creates a rear end collision risk.
3) A Corvette can just stop faster than most cars, so once again a rear end collision risk.
4) Big SUV's and big Pick-up trucks. These drivers sit so high up that they low brake lights of a C3 aren't that noticeable.
I think the LED third brake light is a really great idea.
Dave
. Also, I'd like only the front lights to come on, when you use the switch you get front & rear. I figured something like a relay, just haven't stared at the circuit diagrams enough yet.
Dave
Roger
Glad I could provide some inspiration!
Dan
What is the size of the hole where the key swich is placed?
3/4"?
Can anyone advice me on where to find such a LED?
I´m not looking for a LED like the ones on mashines or so, I wan´t it to be real intense and wide.
Do you think it will work or will it just look silly with a single LED?
