Carb question/Hot start Problem
Old Nov 13, 2008 | 02:05 PM
Mikey74Stingray's Avatar
Mikey74Stingray
Default Carb question/Hot start Problem
I have a Edelbrock 1411 750 cfm carb on my car.
the car have high compression pistons and a mild comp roller cam.
Question is: How can I tell if the carb is to much for the car?
I'm having hot start problems where it will flood very easily when the car is hot.
Thanks in advance!
Old Nov 13, 2008 | 02:21 PM
wombvette's Avatar
wombvette
Thanks in advance!
750 is probably too big for any small block, but at the same time should have nothing to do with flooding on a hot start. In theory the larger the CFM the leaner it would be.
Old Nov 13, 2008 | 02:38 PM
WillEE's Avatar
WillEE
My experience with the Edelbrock carbs is that since the fuel is stored at the base of the carb it gets hotter and more commonly results in hot-start issues vs. a holley which has the float bowls hanging off to the side with more air cooling going on. I've noticed this and also that with the Edelbrock carbs they will require more pedal pumping after they sit overnight to start. Never had this problem with Holley. Not saying that edelbrock carbs are inferior just a few things I've noticed while I've run both brands and various sizes over the years. You can improve the fuel heating issue by installing a phenolic spacer (assuming you have enough hood clearnance) to provide insulation between carb base and manifold - $20. I agree that your engine would run much better with the 600-650cfm Edelbrock. I had what sounds more HP 350 build than you're describing several years ago and found it ran significantly better with the 600cfm than the 750 and also better mpg so the 750 really makes no sense for a medium-build 350.
Old Nov 13, 2008 | 02:44 PM
SH-60B's Avatar
SH-60B
I don't even touch the gas pedal to re-start mine when it's hot. If you do then you're giving it an accelerator pump shot that it doesn't need.
Old Nov 15, 2008 | 01:21 AM
Desert68's Avatar
Desert68
I live in Phoenix and during the summer the gas in my '68 327 w/ Q-jet will 'percolate' and dribble into the carb when it's hot outside and I've been driving the car hard, then shut it off. I don't know if this happens with Edelbrock carbs, but I thought I'd mention it because from what I understand it is not uncommon these days with the belnded fuels that are out there for reduced emissions.
Old Nov 15, 2008 | 10:28 AM
1972warship's Avatar
1972warship
I have the exact same carb on a small block 385, and was having the same issue in the summer. I have very limited hood clearance so I bought an edelbrock insulating spacer and a shorter air filter. This pretty much resolved the issue.
Just an FYI:
Old Nov 15, 2008 | 10:45 AM
rponfick's Avatar
rponfick
I agree with SH-60B. I had a tremendous load up problem after trying a hot start on my '73 BB with 4781 carb and the replacement 770 Street Avenger that replaced it. Someone on the Forum suggested not touching the gas pedal upon restart. That solved my problem.
Ralph.
To Carb question/Hot start Problem
