Roller Rockers
Old Nov 13, 2008 | 04:16 PM
jakesindy's Avatar
jakesindy
Default Roller Rockers
Does anyone know if roller rockers will fit under a stock LT1 valve cover
Old Nov 13, 2008 | 04:21 PM
Gordonm's Avatar
Gordonm
Yes they will if you use the thick valve cover gaskets. I use the Fel Pro Fpp 1604 gaskets.
At least mine do. I run CC full roller rockers. I did have to pinch in the breathers under the covers slightly to fit in between the rockers.
Old Nov 13, 2008 | 06:55 PM
LeMans Pete's Avatar
LeMans Pete
St. Jude Donor '13-'14
Contact restoration station (www.restoration-station.com), they have created short nuts that you can use on your roller rockers. I also think Comp Cams has a short nut , PN 4600-16 that works as well. No thick gasket, no tall valve covers.
Old Nov 13, 2008 | 07:49 PM
Les's Avatar
Les
Same here while using Crower full roller rockers. You'll be able to see where you need to crimp the breathers.
Old Nov 14, 2008 | 06:28 PM
KENS80V's Avatar
KENS80V
I'm using them too. I have Harland Sharp roller rockers. The drippers need to be ground off and the poly lock nuts were shaved down slightly to fit with stock gaskets. My heads aren't factory though...they are SR Torquers.
Old Nov 21, 2008 | 08:13 AM
jakesindy's Avatar
jakesindy
Thanks for all the help I am going to change them this week end With 1.6 ratio
Old Nov 21, 2008 | 01:12 PM
toddalin's Avatar
toddalin
Ohhh, that's another matter. On most stock heads, you will also have to elongate the areas that the pushrods pass through or they will rub. There's a tool specifically designed that holds a bit to grind out that area for for this. But you would probably want to remove the heads to keep from getting metal garbage in the engine. (Could probably be done on the engine if really careful.) Either way, you would need to remove the intake manifold to ensure that you don't get shavings in the lifter valley. And while you have the manifold off, you may as well have "trash screens" epoxied in the valley. (I did as cheap insurance.)
1.5:1 and 1.52:1 rockers do not create this interference.
To Roller Rockers
