Griffin Universal Radiator selection, please verify
Old Nov 14, 2008 | 11:46 AM
Exdeath's Avatar
Exdeath
Default Griffin Universal Radiator selection, please verify
Looking for verification that I am selecting the correct Griffin Universal for a 1979 L-82 Automatic Transmission with minimum/no modification to install. (I am budget minded so please do not recommend Dewitt)
Any opinions / recommendations are also welcome!
Thanks in advance guys, you have always been a great help!
Part Number: GRI-1-25272-T
Radiator Style: Crossflow
Overall Width (in): 31.000 in.
Overall Height (in): 19.000 in.
Overall Thickness (in): 3.000 in.
Row Quantity: Dual-row
Radiator Finish: Natural
Radiator Material: Aluminum
Transmission Cooler: Yes
Inlet Location: Upper driver side
Inlet Size: 1 1/2 in.
Outlet Location: Lower passenger side
Outlet Size: 1 3/4 in.
Tube Size: 1 in.
http://store.summitracing.com/partde...880+4294906186
Old Nov 14, 2008 | 12:15 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Yes, that is exactly what I have in my '78. Mine is a 4 spd so I don't need a transmission cooler. I assume you have that covered? The rubber isolators for the top clamps need to be removed. I made thinner ones out of heater hose. For the lower hose I used one like this...
http://store.summitracing.com/partde...5&autoview=sku
Old Nov 14, 2008 | 12:18 PM
Exdeath's Avatar
Exdeath
Originally Posted by burners
Yes, that is exactly what I have in my '78. Mine is a 4 spd so I don't need a transmission cooler. I assume you have that covered? The rubber isolators for the top clamps need to be removed. I made thinner ones out of heater hose. For the lower hose I used this...
The transmission cooler is covered, at least it says it is in the description of the radiator.
Just to verify, with the Griffin, the stock lower radiator hose does not work due to the angle of the outlet?
Will a 24in flexible hose work for the upper hose as well as the lower for this application?
Old Nov 14, 2008 | 12:33 PM
Taijutsu's Avatar
Taijutsu
Default Think original?
I wanted better cooling so I could run the AC on a hot day w/o problems. I read where a forum member had his stk rad recored w/extra core. He had a 3 core changed to a 4 core, very cheap in comparison.
I did the same and am very happy. The new rad fits perfect and looks stk. My new rad w/dual spals does everything I want. On fwy temps run steady 180-190 w/AC on.
Before you spend big $, check this out. JMHO
Ricisan
Old Nov 14, 2008 | 02:45 PM
thegazman's Avatar
thegazman
Default thegazman
Genesis Auto Parts carries an all aluminum radiator for $181 that they claim is a direct fit in a 77-80 Corvette. They advertise here in Forum
Old Nov 14, 2008 | 03:24 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
FYI, if you want to forgo adapting another rad to your application, Griffin #6-277AF-BAX is the direct match for 77-82 Corvette with auto trans, supporting up to 400HP. Don't have a price, tho.
Old Nov 14, 2008 | 03:58 PM
burners's Avatar
burners
Cruise-In V Veteran
Yep, the lower outlet on the radiator is angled completely different on the Griffin. I just measured my hoses and the lower one is more like 18" (all told with the connectors it is about 21"). The upper hose measures about 24" total but I just used the stock type hose. I think I had to trim it a couple of inches but it works fine.
Old Nov 14, 2008 | 05:53 PM
MikeC's Avatar
MikeC
That is the Griffin I have in mine. For the lower rad hose, I torched the old brass outlet out of the old rad, connected it to the rad via a short piece of universal rad hose and the hooked up the stock hose. It rubs the frame a bit but after a few years I have noticed not appreciable wear on the hose.
Old Nov 14, 2008 | 07:38 PM
WESCH's Avatar
WESCH
Hi
I bought a universal Alu rad from Summit for 180 USD and just welded some alu tubing to the inelt and outlet in order to be able to use the original hoses.
This is a all welded alu rad from NORTHERN. Most others like GRIFFIN are glued with compounds.
I had to take the 29x19 Inch one due to 68 having slightly smaller rads. All other C3 can use the 31x19 inch universal racing rad.
Here 2 pics of the original copper rad with the universal alu rad
Here the modified alu rad. I also added a drain **** to it like the original had.
Rgds. Günther
Old Nov 15, 2008 | 08:53 AM
Exdeath's Avatar
Exdeath
Default Thanks again!
Cool guys thanks to everyone that replied!
I went ahead and ordered the Griffin Universal I originally listed, but thanks for all the alternatives offered.
To Griffin Universal Radiator selection, please verify
