Harmonic balancer removal (in car)
Old Nov 18, 2008 | 06:13 PM
langg's Avatar
langg
Default Harmonic balancer removal (in car)
Hi.
I have a BB in my 75. I want to change the harmonic balancer. Will I be able to remove/install an 8 inch H. balancer without raising the engine? It looks close with the crossmember indentation.
Thanks for any help on this.
Langg
Old Nov 18, 2008 | 07:26 PM
Oldguard 7's Avatar
Oldguard 7
You should be able to get it out without raising it.
Old Nov 18, 2008 | 08:16 PM
Durango_Boy's Avatar
Durango_Boy
Originally Posted by langg
Hi.
Langg
It will come out, if only barely, but it will come off.
The hardest part is the articulation of the wrench and ratchet on the removal tool...and if the balancer has never been off expect a fight. Lubricate the threads of the removal tool with engine oil and keep it lubed through the removal process. The threads will get hot fast and you don't want the threads to get screwed up.
Old Nov 18, 2008 | 10:11 PM
gve's Avatar
gve
I have a 70 BB I had to raise mine to get it past the front frame.
Old Nov 20, 2008 | 07:08 PM
langg's Avatar
langg
Thanks for the help. I'll try without raising the engine.
To Harmonic balancer removal (in car)
