Pipe Expander Use?
Old Nov 19, 2008 | 08:26 AM
bytor's Avatar
bytor
Default Pipe Expander Use?
I'm installing a Mid America true duals setup on my 78. I removed the old stock setup last night without much of a fight except for the mufflers. I had a heck of a time getting one of the mufflers separated from the pipe on the inlet side. The old clamp had crushed the pipe and made it nearly impossible to remove. With a little patience, I got it removed. I plan to reuse the Dynomax super turbo mufflers because they are in good shape with no rust. My question is can I use an exhaust pipe expander to remove the crush ring caused by the old clamp for a good fit on the new pipe?
Old Nov 19, 2008 | 08:57 AM
SH-60B's Avatar
SH-60B
That's how I do it.
Old Nov 19, 2008 | 09:17 AM
gerry72's Avatar
gerry72
Sure. Don't know if you've ever used one before, but you expand the tool to the point it's a little on the loose side in the uncrushed pipe section then hammer the expander through the crush. It's easier if you work the diameter up a little at a time.
Old Nov 19, 2008 | 09:24 AM
bytor's Avatar
bytor
Nope, never used one before. Sounds like a piece of cake. Thanks for the guidance!!
To Pipe Expander Use?
