Early Black Friday Sales Event
65-82 Offsets – $959.99 plus $390 Core
65-82 T-Arm Assem - $292.49 plus $300 Core
63-82 T-Arm Bolt & SS Shim Kits
L&R Shock Mounts
All can be found here
http://www.vansteel.com/index.cfm?fu...&SubGroup=1892
New Bearing & T-Arm Assemblies – 30% Off ***Please see BAN part numbers***
http://www.vansteel.com/index.cfm?fu...t&SubGroup=201
63-82 Bare Offsets – 397.99
http://www.vansteel.com/index.cfm?fu...p=1801&ID=1837
All Sway Bars C2-C6 – 25% off
http://www.vansteel.com/index.cfm?fu...ps&Group=17000
65-82 New Delco Calipers - $139.99 each no core
Fronts – Part Number FB-01N & FB-02N
http://www.vansteel.com/index.cfm?fu...t&SubGroup=304
Rears – Part Number RB-01N & RB-02N
http://www.vansteel.com/index.cfm?fu...t&SubGroup=307
65-82 Parking Brake Hardware Kits - $41.99
65-82 Parking Brake Shoes - $32.49
Rear Backing Plates - $23.99
http://www.vansteel.com/index.cfm?fu...t&SubGroup=306
8” Spring Bolts - $14.99
http://www.vansteel.com/index.cfm?fu...p=1502&ID=1670
65-79 Diff Kit - $94.99
http://www.vansteel.com/index.cfm?fu...p=1929&ID=2660
63-82 Rear Spindle Bearing Kit - $26.99
http://www.vansteel.com/index.cfm?fu...up=201&ID=1542
Trailing Arm Rebuild Kits - $143.99 Part Number TARP….
http://www.vansteel.com/index.cfm?fu...&SubGroup=1801
63-82 Adj Strut Rods - $115.
63-79 http://www.vansteel.com/index.cfm?fu...p=1602&ID=1773
80-82
http://www.vansteel.com/index.cfm?fu...p=1602&ID=1774
1350 Spicer Joints - $23.99
http://www.vansteel.com/index.cfm?fu...p=1002&ID=2363
Call for Pricing on our all New Wilwood Kits that use 13” & 14” rotors as well as Wilwood’s new D8 Caliper that utilizes stock rotors and pads.
http://www.vansteel.com/index.cfm?fu...ps&Group=23009
Also call and check on our pricing for Hawk Brake Pads.
http://www.vansteel.com/index.cfm?fu...ps&Group=20001
65-82 Rotor Packages
http://www.vansteel.com/index.cfm?fu...&SubGroup=1953
**There are many different items we can work out pricing on. If there is anything else that you are interested in, please let us know and we will see what we can do for you. Quantities are limited on some items and other items may be drop shipped if not in stock.
www.vansteel.com
Please contact Dan Dorsett or Paul Lesinski with any questions.
800-418-5397
727-561-9199 outside US
