Cast iron dist. ID?
Old Nov 20, 2008 | 01:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
Default Cast iron dist. ID?
Cast Iron GM points
Has a steel band around it with the #111098 and 2 D 9
Down lower on the shaft itself there is a 620 stamped on it.
Has a little spring loaded door in the bottom Im guessing for oiling.
Anyone know what this came out of?
Old Nov 20, 2008 | 02:15 PM
1Fordman's Avatar
1Fordman
With a 6 digit part # and the oil door you have an old distributor. April 9 1962 date code? The old 265's and 283's had cast iron housings.
Old Nov 20, 2008 | 02:27 PM
cv67's Avatar
cv67
St. Jude Donor '05
Was wondering if it was worth anything, cleaning out the garage and some old stuff Ill never use, thanks
Could it be off anything GM back then or somethign specific?
Old Nov 20, 2008 | 09:19 PM
1Fordman's Avatar
1Fordman
I found an old book that lists the distributor part numbers. I think you're missing a digit in the part number. Is your distributor an 8 cylinfer one and does it have a window in the cap to set the dwell? If it does it's a 57 -up. If no window it's a 55 or 56.
I found a 1110987 which is for a 1962 327 either 250 or 300 hp.
Old Nov 20, 2008 | 11:08 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You sure it's not 1110891, this is a common distributor on 1957-1961 cars. It has a long tube with a flipper lid for oil. This distributor was in production a long time, even in to the 80's so a date code could be 62 72 or 82. But the band around it thing has me confused. All the early distributors had a metal plate riveted to them with the part number and production date stamped in it.
Someone correct me if I'm wrong, but banding did not start until 62.
Double check your part number and post again. I've got the old books to look this up in.
Willcox Inc.
To Cast iron dist. ID?
