Serious Hesitation Almost Stall
Old Nov 22, 2008 | 04:37 PM
R Vette's Avatar
R Vette
3rd Gear
Default Serious Hesitation Almost Stall
Hi,
I'm new to the forum. I actually joined to try and help my dad figure out what's wrong with his 74. It has a seriou hestitation (almost to the point of stalling) when you get on the gas. You end up having to pump the pedal to get it going without stalling. Once you hit the higher RPM it seems to run fine.
While driving, we smelled burning oil as well. So we got udner the car and saw that there was oil EVERYWHERE. It looks like the oil was burning off where the header meets the downpipe. Looking through the engine bay, the oil seems to be from the valve cover down.
So, my first though is that the valve cover gaskets needs repalcement (has never been replaced), but that wouldn't cause the hestitation. Maybe they are two seperate issue?
Any thoughts or suggestions on what the issue could be and potential solutions could be would be greatly appreciated.
Thanks in advance for the help!!!
Old Nov 22, 2008 | 05:15 PM
OMF's Avatar
OMF
Welcome!!
The first thing I would do is remove the aircleaner and look down into the carb. While doing this move the linkage to wide open throttle (All done with the engine off). What your looking for is a nice consistant squirt of fuel from the accelerator pump squirters, which are in the primary bores (the small ones). Check this out and report back.
Old Nov 22, 2008 | 06:10 PM
Durango_Boy's Avatar
Durango_Boy
Yeah separate issues. Fix the oil leak, clean it all up, and drive it and check for oil.
The hesitation is probably timing based. Do you have a good timing gun?
Old Nov 22, 2008 | 09:39 PM
Dream Ride's Avatar
Dream Ride
St. Jude Donor '09
I'm thinking you've got a piece of trash in the bowl. When you 'get on it' it picks up and gets in the needle seat. When you pump the peddle it flushes back into the bowl and lets the engine catch back up causing a steadier flow allowing the trash to settle back to the bottom until that 'gettin on it' again.
And I'm guessing that when you say 'get on it' you're already cruising down the road and you punch it.
Old Nov 22, 2008 | 10:07 PM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
I agree with that. When you do put a light on it, check to see if it's advancing. Your timing can be right, but it will hesitate badly if your advance isn't working...
Old Nov 22, 2008 | 10:35 PM
Ironcross's Avatar
Ironcross
Originally Posted by sstocker31
Welcome!!
Old Nov 23, 2008 | 10:57 AM
R Vette's Avatar
R Vette
3rd Gear
Welcome!!
First, thanks for alll the responses, I really appreciate it.
So, i took a look and it seems that i am getting a decent 'squirt' when pulling the throttle linkage to WOT. It probably could be a little stronger (as the carbs have never been cleaned), but I think it's a strong enough stream to get her going.
Dream Ride,
I took a look down into primaries and secondaries and didn't see anything. Actually for a 35 year old carb (that has never been clearned), looked pretty clean. Is visual inspection enough to verify this?
Avette,
I'm going to take a look at the timing now. I read Barryk's write up (which had alot of great information). Based on that write up, I'm going to set the initial with the a rubber band around the centrifugal springs then take it off and see if the timing changes. If it does, it points to the centrigifual springs, right?
Will let you know how the timing goes! Thanks againg guys for the help.
Old Nov 23, 2008 | 12:23 PM
OMF's Avatar
OMF
Check the timing and report back. If everything is original you might consider spending a few bucks and rebuild a few of the more critical items (carb,Ignition). But first lets find out whats causing your problem......What do your plugs look like? check all eight.
Old Nov 23, 2008 | 04:31 PM
R Vette's Avatar
R Vette
3rd Gear
So we checked the timing. It was at like 12-14 degrees, so we adjusted it back to 8.
I did it based on Barry's instructions (putting a rubber band around the centrifugal advance). When we took it off, the timing did not change, so the springs/weights in the centrifugal don't seem to be the culprit. We donlt have a dial back gun, so we didn't set total timing.
We took it for a ride, seemed to be better, but still had a hesitation.
So I'm guessing it is probably the carb? I did notice that the primaries seemed to be open all the time. Aren't they supposed to close?
Old Nov 23, 2008 | 11:57 PM
OMF's Avatar
OMF
Exactly how far open were they?? They are supposed to be open just a hair for the Idle.
Old Nov 24, 2008 | 01:15 AM
Droshki's Avatar
Droshki
Im guessing he's talking about the choke on the primary, not the throttle blades down inside it.
On the bigger picture, I'm still rooting for the accel pump theory. You really have to get a healthy squirt to overcome the sudden acceleration. Someone unfamiliar with what this looks like might think a half-volume spray "a decent 'squirt' " looked pretty effective, where I would be expecting almost more of a "spray".
Does it spray gas from the beginning of the stroke to the end? Or only during part of the movement of the accelerator pump?
Im pretty suspect of an accel pump that hasn't been replaced in 35 years.
Old Nov 24, 2008 | 07:37 AM
Avette4me's Avatar
Avette4me
With your timing gun hooked up, rev it a bit. Your timing should advance.
To Serious Hesitation Almost Stall
