rear trailing arms
Old Nov 23, 2008 | 06:11 PM
vett 68's Avatar
vett 68
Default rear trailing arms
could anyone tell me if it's a good or bad idea to put in off set trailing arms i;m thinking about it so i can put 2 inch wider tires any imput would help thanks pete
Old Nov 23, 2008 | 06:23 PM
Gordonm's Avatar
Gordonm
Won't hurt a thing. If you are planning wider 15 or 16 rims and tires it is going to be needed.
Old Nov 23, 2008 | 06:40 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
...but, just to add, IMHO avoid poly bushed TA's as they move in more than one plane during suspension travel. Also, with deeper back-spaced wheels (max BS is realistically ~5" w/15's) you'll likely need a clipped width rear main leaf. Got mine from Guldstrand, but I believe VB&P among others can take care of that too.
Old Nov 23, 2008 | 08:20 PM
rcread's Avatar
rcread
My offset trailing arms are from Van Steel and I'm very happy with them. I say go for it.
Old Nov 23, 2008 | 09:37 PM
X21CrMoV5-10's Avatar
X21CrMoV5-10
2nd Gear
The tires will be hitting the frame as well as the arms. Look straight up from underneath the car and you'll see.
Old Nov 24, 2008 | 05:36 PM
Jim_Harrison's Avatar
Jim_Harrison
I agree, you will not be able to get that much more backspacing from the offfset arms because of the frame. I have 4 3/4 backspacing on both my 16 inch CCW's and 17" TT2's. I'll do the same when I buy my 18X11 CCW's. You will need to trim the spring for 16's might be all right with 17's depending on car height and no problem with 18's....I hope. I did have to route my emergency brake cable to the backside of the trailing arms. That said I do own a set of double offset arms which I will put on someday but for the extra ridgity.
Old Nov 24, 2008 | 11:06 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
please explain
Old Nov 24, 2008 | 11:21 PM
TimAT's Avatar
TimAT
Stock T/A's, parking brake cable in the stock location, sway bar, stock (F-41) spring, stock spring bolts, with 17x9 4" backspace wheels with 285/40 Goodyear Eagle F1 GS-D3 tires. The inner diameter of the wheel is OUTSIDE of the end of the spring and everything else. Lots of room on the inside.
To rear trailing arms
