82 transmission Swap
Old Nov 25, 2008 | 02:02 PM
dnickum's Avatar
dnickum
3rd Gear
Default 82 transmission Swap
Good Afternoon everyone, I just recently purchased a 82 Collector Edition and I would like to install a manual transmission in it. Has anyone done this that can tell me what all is involved in doing so?
Thank you,
David
Old Nov 25, 2008 | 02:13 PM
Durango_Boy's Avatar
Durango_Boy
Thank you,
David
There have been a lot of members doing this kind of thing, and to be honest you'll get a lot of good threads and walk throughs and pictures by doing an advanced search using some key words.
Manual Transmission Swap
There are also a few vendors that offer bolt in kits for new 5 speed transmissions.
Old Nov 26, 2008 | 01:50 AM
Gale Banks 80''s Avatar
Gale Banks 80'
I went from a Turbo 350 to the 82 style 700R4 in the late 80's. I have recently installed a Tremec 5 Speed. Probably the best way would be to go with Keisler Engineering as they sell every Part You need all in one Kit. The driveline you have is the same lenght for both Trans. Putting the Clutch Brake pedal setup in is no small project You might consider replaceing Your Brake Booster when You have this all apart. If You use the stock Mechanical Clutch parts you will have to Weld a braket to the Frame. If your going to use a Hydaulic System I like the Tilton one the best. You can also use a Tremec 6 Speed but You will have to modify the Trans Tunnel and it weighs 33 lbs more. You can modifiy your Crossmember pretty easy for the new trans but by replacing it You can run a Dual Exhaust so you might as well.
Old Nov 26, 2008 | 03:28 PM
KeislerSales's Avatar
KeislerSales
Thank you,
David
It was nice talking with you today David, feel free to contact me anytime if you have any further questions. Good luck with the `82!
To 82 transmission Swap
