Hello brothers,
help me please.I have holley on my 1975 vette and I need rebuild kit for it.How to find out what kind of holley carb I have?Is there anny numbers on a carb wich can tell the carb model?
And where is beter to buy the rebuild kit?
Thank you
Best Regards
Marius
I don't' know where the numbers are on a Holley, possibly on the float bowl or the air horn but here is a good place to get a rebuild kit. http://www.carburetion.com/ If you call them they can probably tell you where to find the numbers you need to get the right kit. Or I'm sure other members know where to find the numbers. Here is a good reference for Holley numbers.
I think that your B0457-2 is actually 80457-2 and and that makes it a 600 cfm vacuum secondary carb. Most Holley carb kits are usually manufactured to cover several different carbs I'm sure with this number you can get your kit either online or at a local parts store.
