headlight assembly removal for painting
Old Nov 27, 2008 | 05:25 PM
goldengoat2's Avatar
goldengoat2
Default headlight assembly removal for painting
I am preping my 78 for painting, What is the best way to remove the headlight assembly. thanks
Old Nov 27, 2008 | 05:31 PM
john roth's Avatar
john roth
If you can avoid moving it...........do. It's a lot of work tearing it apart and it's more work putting it back together (4 years later). Minimize.
Old Nov 27, 2008 | 06:08 PM
thegazman's Avatar
thegazman
Default thegazman
If you are painting your car a metallic color leave the headlight covers on. I removed mine when I had my 79 painted and they painted the covers separately. When you stand in front of my car the headlight covers look like they are a different color as the metallic lays differently than the rest of the hood and front end.
Old Nov 27, 2008 | 07:12 PM
goldengoat2
it's red, no metallic
Old Nov 28, 2008 | 08:46 AM
thegazman's Avatar
thegazman
Default thegazman
If it's non-metallic red you will okay taking the headlights for painting. You get a better job around the edges. Whiles you have the headlights out install all new plastic bushing and pivot points for continued smooth headlight operation. It's extra work, but worth the effort.
Old Nov 28, 2008 | 09:10 AM
eastltd's Avatar
eastltd
Do you still have the bumper reinforcement and cover in place? If so you will struggle to get them out. I found it was best to drop them out the bottom. You may have to remove the grill and lower valance to gain better access. There are only 4 bolts holding them in place. Once you you have them loose, fish them out. Its not easy, but you can do it. Careful with the rad!
After removal, check the header bar close for any signs of rust or separation and make any repairs before you paint.
When you're ready to reinstall the units, tape every thing up well to avoid chipping the fresh paint while installing and adjusting the assemblies.
I have several pics of the process. PM me if you need them.
Old Nov 28, 2008 | 05:40 PM
1974ta's Avatar
1974ta
If you can come up with an excuse to pull the radiator and support the job is a lot easier and you will be less likely to damage the paint putting them back in place. However, pulling the radiator and support can have its challenges too.
Old Nov 29, 2008 | 06:25 PM
goldengoat2
I got them out,, thanks
To headlight assembly removal for painting
