68 turn signal swich replace
So does anyone know if a $35 69+ GM switch will work?
I noticed that Advance auto has a 68 switch with what looks like ad adapter harness:
http://shop.advanceautoparts.com/Pro...pe=832&PTSet=A
Is this just a generic GM switch with an extra harness piece?
The imported switch is available for your car 55.30
http://willcoxcorvette.com/product_i...oducts_id=1427
and the correct repro is available 62.00
http://willcoxcorvette.com/product_i...ducts_id=24725
Willcox
I don't know the niceties of the inner workings but here are a few comments as to why they are unique. Four-way (emergency) flashers were introduced/federally mandated in 1967 (1966 in New York State!). Thus the earlier C2 switches were different. The ignition switch was on the dashboard in C2s. The same was true in 1968. But in 1969 the feds mandated a locking steering column and the ignition switch was moved there from the dashboard. Thus the T/S ***'y had to be changed. Jim Shea will know in what way, I do not. Thus the 1967-68 T/S is a bit of an orphan.
I hoarded a couple but recently sold them on EBay.
