Check out "Speed City" parts. Look on this forum under parts for sale. I purchased one of their Distributors w/tach drive several years ago and it works fine.
I also used the Dragon Fire dist.
I did find the sensor wires crushed under the HEI module.
after I FIXED THAT EVERYTHING HAS WORKED PERFECTLY.
(poor Assemble)
69VETT
Make sure the power lead is 12V. Points distributor power will come from a resistor wire that drops the voltage. If you use that, it won't function properly. You need to remove it and run a standard wire.
I have a MSD tach drive distributor and it was a noticable difference than the my old stock unit that had been rebuilt by a
guy who is considered very good.
Is there ANY HEI distributor that will fit under the shielding? my dizzy cam is really worn in my 454 and I have had thoughts of replacing this with aftermarket but really want to keep the shield in place if possible.
