Side Pipe Muffflers Questions....
I'd like to maybe get a hi-rise hood someday but they aren't cheap and its not on the top of my list.
Additionally, sometimes on residential streets it can be an annoyance looking around the air cleaner so as to not mow down any children. It's not bad, but its there, I mean you sit so low in the car to start with. I think a high rise hood is only going to make it worse.
Pics in album in profile if you're interested- it really doesnt look that bad.
I would be interested in what others have done though, as all the hoods out there dont really seem to add that much clearance.
It is slightly off center- which took me a while to figure out that the engine is not centered in the chassis because ot the steering gear. It's not real noticable- maybe an inch.
I am evaluating my 500 hp/500ft lbs options between something like a 144 blower, a vortech sidemounted supercharger or just a stout build-up. Then I gotta figure out how to keep it under a hood or just go hoodless for a while.
You could probably achieve your goal going NA, but I wonder if the cam wouldn't be so big that you'd have streetability issues.
Mine is a 144 B&M, same thing as a Weiand. I love it, its instant on, and the blower whine when you nail it is almost unearthly. Besides, nothing says "fast car" than just....couldnt...fit it...under the hood!
The one benefit I see to centrifugal blowers is the easier ability to intercool, which seems pretty non-existent with a roots type.
Now just need to save up the money.
You should be aware by now that at a minimum you are going to have to buy forged (low compression) pistons to do this. Forged crank and H-beam rods are also desirable, as is o-rings in the block, unless you dont mind replacing head gaskets
.Im having a 4-bolt short block, all forged 383 being built for me and its going to be right around 4K, but thats internally balanced and includes roller cam, timing gears, chain and cover, lifters, oil pump and oil pan, and aforementioned o-rings. Pretty much bolt on my heads and blower, stick in the dizzy and go.
I guess my point is that you pretty much have to make the decision about the blower before you even start collecting engine parts.
Seriously, yes, you can get away with less than I described, but it's a matter of longevity, especially without forged pistons.
But...
I have been built many engines through the years, but a very close friend of mine insisted on freshening up the old girl....He has been building engines for over 40 years and is a well known engine builder in the NHRA Super Stock circles....
The first 383 we built had Lunati street rods, steel crank, flat top TRW pistons, Edelbrock RPM aluminum heads, Edelbrock Scorpion Intake, Holley 750DP and a Comp 282S.
We made a warm up pull on the Dyno stopping at 5200....The old girl made 448Hp @ 5200 and 451 ft. lbs. @ 4500.
Not bad considering that was the first pull.....
I guess you want to know the rest of the story????
It's around 8.5-1 so I run a smallish top pulley to spin the blower relatively fast but keep the rpms way down. This results in 5-6 lbs of boost. That's enough to blow the tires off anyway so it's a fun cruiser.
Shane
It is my understanding that if you are going to use a centrifugal, there are a few issues since you are actually pressurizing the carb.
If a roots or screw type, no special carb is needed, but I think size selection is going to based (like any other application) on the complete build of the engine, specifically heads and cam, not just the fact that you have a blower. I do know that you do want to fatten it up a little, because the last thing you want to do (literally,maybe, ha ha) is to lean out a supercharged engine. Better to run a little rich then burn up your pistons.
That being said, I have no real expertise in this area.
I can tell you what I am running as a reference point. I have a Holly 850 DP with #71 jets in the primaries and #80 in the secondaries. I have spacer/isolators under it for heat protection; compressing air creates heat.
Probably a good thing for you to do is to download the camquest software from Comp (although I had poor results with this), or get a copy of desktop dyno (Ill send, if you PM me a email address), and play with the numbers until you see what you want. I am not at all convinced that DD factors in the boost correctly though.
We are getting sooo far off topic though, I wonder is we should move to a new thread. This stopped being about sidepipes a long time ago
(A shorter answer might have been that I think you will be fine with a 750 DP if you upjet it.)
Last edited by Droshki; Dec 3, 2008 at 10:34 AM. Reason: Did I make that complicated or what?
Shane
I bought my speed demons on closeout from Summit and converted the power valve circuits myself. It's a DIY mod or a carb shop can do it for you.
http://www.fordmuscle.com/forums/tec...d-engines.html
I had talked to a few racing buddies of mine about the side pipes for higher HP applications and the Hooker Maxflows were recomended. They seem to flow better at the higher RPM's. I have been talking to some other forum members about braking, since my car came with manual everything. I am still not convinced that the manual brakes are the best route for my project. Any ideas?
I've had the Hooker glasspacks...too restrictive...Now I have the Hooker Max-Flo's..they perform better and I love the sound at WOT. and very hard to beat the price. The spirals sound tinny IMHO.
