Supercherger on a ZZ4
I've got a ZZ4 w/ no mods and I'm looking to increase substantially from the 355hp. I was considering pouring the money into my BB but I've been reading more about superchargers lately and I'm reading advertised gains of 150hp for only a few thousand $$'s. However, they also recommend compression ratios for the most part around 9:1. The ZZ4 is rated at 10:1.
Anyone ever tried this? Am I just going to blow up a pretty solid mill if I strap a supercharger on it?
Dan
Last edited by Dantana; Dec 1, 2008 at 05:08 PM. Reason: Apparently I invented a word - "Supercherger"
Seriously though I was looking at a chart the other day and off the top of my head, with static 10:1 CR, you are going to be looking at about 13.5:1 or higher with boost. You are going to have severe detonation. Maybe the ZZ4 knock sensor will dial back the timing and save your cast pistons, but I wouldn't bet on it.
I know where you are at, the ZZ4 is nice, but really could use a little more power. I've thought on this a while. Really the safest bet is cam/head upgrade, but thats not cheap and its a PITA. (although if your buying a new blower, thats not at all cheap either, heads and cam might be cheaper)
Now, there are a hell of a lot of guys spraying (NO2) relatively high compression engines with cast pistons over on the C4 FI board, but Im not even sure Im comfortable with that. I think most of them are no higher than 9:1.
in my OPINION, the only way to go boost, is with all forged internals. Even then you're not completely safe- I broke a forged piston in my C3 with about 10 PSI. (at 8:5 CR)
Plus, read the direction sheet on one of those centrifugal blowers. Good god almighty- Ill strap a roots on and cut a hole in the hood any day
I think it said 20 hours by a trained professional, expect 2X that for DIY.
I just looked it up. 10:1 CR + 8 PSI boost = effective compression ratio is 15.24 :1
Like Droshki said, 8 - 10 psi max unless you rebuild the internals.
I am going 8.5 CR on my current 383 build, which should put me at about 12:9 with boost, and I'll be using forged pistons, crank, and H-beam rods, and copper head gaskets and o-rings in the block to mate up with them.
I mean, seriously, if it works, let me know, I'd love to wake up my ZZ4 in my other car, but I'll let you got first
I sent away for their free info kit and to my surprise found they made a kit specifically for the ZZ4... (I don't know why they don't directly advertise this on their website... if they do I couldn't find it...)
Anyways I'll copy down some of the specs from the brochure I received.
-ProCharger Kit: C2
-Intercooler: N/A
-Boost: 8 psi
-Engine: ZZ-4 Crate Motor (and specs associated with)
-Carb: 600 Holley (can come with kit- dyno tuned)
-Naturally aspirated HP: 355
-Est. PC HP: 497 (40% increase)
-Part Number: 1CD110-C2 or 1CD100-C2 (info from brochure is 1 year old)
-Article with a similar application (if not the same one with different part numbers- Here)
I agree though, it sure would be a cool project if it came out OK and was reliable.
Sure you *can*...but...for how long?
I broke a forged piston with only 8.5:1 and 10 PSI
You guys are in for a rude awakening if you try to run that much boost with higher compression motors, especially with cast pistons.Back years ago whin I was running superchargers, the rule we went by was no more than 12-1 dynamic compression ratio. The lower the static compression was the better because you could run more boost and still stay under the 12-1 rule.
Imagine a 433 ci big block with 5.6-1 static compression running 22-25 pounds of boost making ~1200 hp on the street.
CHP(Whipple Stomp) The next graph shows 91 oct. and more power.
