Brake warning light is on
Old Dec 1, 2008 | 05:36 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Default Brake warning light is on
My brake light on the dash came on when I stopped at a light.
Brakes feel fine. no soft pedal, no noise.
I checked the fluid level and the front was a little low, so I topped it off.
I can't find anything wrong, but the light is still on.
any suggestions?
Old Dec 1, 2008 | 05:58 PM
...Roger...'s Avatar
...Roger...
You have a leak or a little air in the system providing your emergency brake is not on by a couple notches.The light senses a difference in pressure front to rear.
Old Dec 1, 2008 | 06:02 PM
Oldguard 7's Avatar
Oldguard 7
It is possible that you have a bubble in your brake system picked up by the pressure differential switch. Take your vehicle to a safe location, speed up to 35-45mph and stand on your brake pedal. The light should go off. If it is electrical, you can unplug the connector at the switch to see if the light will go off. The pdf switch is located on the driver's side. Just follow the brake lines from the master cylinder.
Old Dec 1, 2008 | 06:57 PM
Duke94's Avatar
Duke94
Pull the wire off the pressure diff valve and see if the light goes out. If it doesn't, then the e-brake switch is closed. If it goes out, then the diff valve switch has tripped and you will need to determine why.
Old Dec 1, 2008 | 08:00 PM
Vegas69's Avatar
Vegas69
Would this apply to a 69 also ? I have the same problem, light won't go out. Pretty sure the ebrake is fully disingaged as the light dims but doesn't completely go out when it's the ebrake is off.
Old Dec 1, 2008 | 08:10 PM
baxsom's Avatar
baxsom
it should, these systems all work pretty much the same way
Old Dec 2, 2008 | 07:38 AM
Duke94's Avatar
Duke94
Yes, it is the same.
To Brake warning light is on
