4 speed trans
Old Dec 1, 2008 | 08:20 PM
JER BEAR's Avatar
JER BEAR
Default 4 speed trans
Just pulled my trans out of my 73. Notice i got one plug to fill and another plug to drain. Is this common on 73 trans 4 speed?
Old Dec 1, 2008 | 09:06 PM
tonyv123's Avatar
tonyv123
Not sure when they started to put a lower drain plug on, but if you post the VIN number off of your trans., we can at least tell you the year. It should be factory stamped on the drivers side, on a machined vertical pad directly in front of the tail housing.
Old Dec 1, 2008 | 09:13 PM
wfo76's Avatar
wfo76
Before 70, usually only the M22 had a drain plug.
For 70 and up, all Muncies should have a drain plug.
Old Dec 1, 2008 | 10:39 PM
Z-man's Avatar
Z-man
My '70 Muncie (M21) had a drain plug.
Old Dec 1, 2008 | 10:56 PM
chvet73's Avatar
chvet73
My '73 has 2 plugs.
Old Dec 2, 2008 | 06:47 AM
dmayhew's Avatar
dmayhew
My 71 Muncie has 2 plugs
David
Old Dec 3, 2008 | 01:53 AM
granville's Avatar
granville
Cruising
could some one tell me info on a m21 trans and l82 engine
To 4 speed trans
