New Distributor
Old Dec 2, 2008 | 02:42 PM
captanpants's Avatar
captanpants
Default New Distributor
I'm looking for a new dist for my 73,po installed a 76 i think he used the dist out of the 73 it has tac drive. What years will fit the 350 tac or not,is there a diff in the size? Mine has been converted with a kit,but the advance is all off and i just need to put something in so i can drive it.
Old Dec 2, 2008 | 03:49 PM
hugie82's Avatar
hugie82
I'm having a hard time following you but if you just want to drive it. You can install any small block dist from 55 to the 80s. If its a points dist. use the resister wire and if its HEI use 12v. The tac drive dist was used up to a 74 vette
Old Dec 2, 2008 | 04:56 PM
msandym's Avatar
msandym
Default new
HI - I have a 71 350 , I put on HEI with tach drive from Star Performance (www.starperf.com) . First one blew up within 3 days , replacement (which looked different)
has worked well for year or two . Reasonable price , too .
Old Dec 2, 2008 | 05:52 PM
captanpants
Default Dist
That was what i needed to know ,if any SB would work till get mine fixed THANK'S I'll hit the JYD tomorrow.
To New Distributor
