Heat Issue
He bought the car as a project from someone in Florida. The people there had no intention of running it in cold weather, so when they were putting a new intake on it, they never reconnected the heater hoses. He reassembled the system, installing new nipples into the intake and new heater hoses through the firewall and connecting to the heater core. Even had to reassemble the blower box inside the car. After he was finished with that, he tested it and said the heater blew hot air. That was a few days ago, but tonight he went to drive the car and found that the heat was not working at all.
He manually opened the flap that allows heat into the ducts, I suppose, and had his hand inside the heat box and said that it didn't get hot. He disconnected the heater hoses and blew into the top one and was able to force water out the bottom, so he feels confident that water was able to circulate - at least at some point.
Is there anything else I can have him check that might explain why it stopped working? He never checked to see if perhaps they had left the thermostat out, being a southern car. Even if they did that though, I assume he'd be able to feel at least a little heat. He says there is definitely enough coolant in the system. He ran the engine for a while with the cap off until he could see the level inside the radiator up at the top.
Any help you can offer will be greatly appreciated. Hoping to salvage the pickup trip this weekend, but can't do it without heat.
I look forward to posting a lot more often here once I get the car and start working on it myself.
Thanks very much,
Sean Burgess
Thanks very much,
Sean Burgess
I looked at a diagram that was linked to from another thread about heater issues. Is the valve you're talking about the one that looks like it's very near the heater core anyway? I think it has a white vacuum line connecting to it?
== Sean
Once I've got it, I'll be back here with and update and hopefully everybody can help me sort it out.
== Sean
