Which Thermostat
But there are some who do NOT understand how a cooling system works at all, even though they think they are the only ones who do. To say a lower rated thermostat will cause an engine to overheat because the water isn't in the radiator long enough to cool, is totally laughable.
And the folks who believe that are sadly unaware of reality. They need to do some serious reading and/or wrenching to get a clue as to what really goes on. Of course, just as you suggested, the thermostat only determines the minumum temp that an engine runs. After that its the system's overall capacity that determines how warm it runs.
I've personally run 160* thermostats in hot Southern California year 'round for years and years, with no overheating issues at all, ever. I've never had sludge issues, nor any other issue with that either. And a number of gearhead buddies have done the same thing, also without issue. Letting the engine run at around 160*, assuming your setup is capable of keeping it that cool, helps prevent detonation on pump gas, and allows the engine to make more hp. I even have a couple of buddies who run NO thermostat, and do so, also without issue, they stay nice and cool. Anyone who has played with engine temps on a dyno or at a dragstrip, will tell you, the cooler it runs, the more hp it makes. This stuff is not Rocket Science.............
I see you both are from southern california, explains alot, right there. BBTank
Currently with my 160 it runs around 155-165 no problem. I guess the real question I want answered is how hot can I run a 9.6 compression aluminum head motor without detonation on 91 octane?
I am thinking 180 or 195 to be safe.
Also, I am pretty sure new cars run at 210+. Obviously I will not be able to get away with that much since this is not a new car, but it is worth noting.
If you already knew this, sorry for the redundency, maybe someone will read it that didn't know before!!
BBTank
I think it might be easier to understand when you consider that heat flows quicker when there is a large temperature difference between the coolant and radiator. You can test this by putting an ice cube in a metal pan and sit it out on the counter...it will take a long time to melt...perhaps even an hour. But, sit it in a 350º oven and it will melt away to nothing in under a minute due to the quicker heat flow from the temperature variance. If you let the coolant sit in the radiator then the difference between the coolant and radiator will decrease to a point where there will be no heat flow at all.
So, a thermostat restricts the coolant flow...which is why I remove my thermostat in the summer. Engines without a thermostat tend to run at around 160º anyway...so a 160º thermostat allows an engine to quickly reach it's ambient temperature, but might restrict the coolant flow enough to prevent it from removing heat fast enough to avoid over heating on very hot days when the A/C is running and in heavy traffic. A 195º thermostat is great for cold winters like this one...it not only allows the coolant temp to quickly reach normal levels, but also gets the coolant hot enough to have a nice toastie heater and defroster. I don't really see any use for a 180º T-stat unless you just don't like a toastie heater.
Thus, right now...in the middle of winter...the best T-Stat to install would be a 195º.
I'm just reporting my experience, other opinions may vary!
The same is true for the air flow...the faster air is made to pass through the radiator the faster the radiator removes heat.
Here's another misinformation for you I'm sure, Professor. In Southern AZ it gets to be 115 "ambient" temp. The roads are how hot then??? And that affects my engine by how many degrees?
I have a big block in this kinda temps too. Should I take my T-stat out when it reaches 100* and above?
Pray tell, professor rock n roll, what college class did you have to take to find out ice melts faster in a 350* oven than on your countertop at 75*. I learned that in the 3rd grade in redneck, backwards azz NC.
I invite you to find a big block C3 Corvette and come visit me in late July, early Aug. and we'll go cruise, and put all that high faluting knowledge of yours to the real world test. The hell with physics, books, and college classes. I know what I know, and it has worked for street cars, 8 sec. drag cars for over 30 years.
You got the answers, I got the questions, teach me something Professor, I'm just a dumb ole redneck.
You can put a 100 degree thermostat in it, but it will probably run around a 180. Of course, it will probably run cooler in the winter, but we're usually concerned about the heat.Larry
Not to insult anyone's intellegence, but alot of people don't really understand how a thermostat works, well the theory anyway. In most instances, a clean good working order cooling system will have less of a possibility to overheat if a higher degree t-stat is used. If you use a 165* t-stat, it opens at 165*, and exchanges engine coolant for radiator coolant. A lower degree t-stat will only allow the coolant to stay in the motor untill the t-stat opens again, and the radiator hasn't had time to cool the coolant back down. Once this cycle happens, the t-stat never closes and the coolant is free flowing until the motor overheats. If you use a 195* t-stat, the coolant stays in the radiator longer and has a better chance of cooling down before the next cycle happens.
BBTank
The world doesn't revolve around this damn forum, and I've been around the world, twice. And I still got a limp to prove it, 14 years later.
I thought this is supposed to be fun, informative, and a place to talk to others that have the same interest, and it's even broken down into types of interest too.
My neighbor is an engineer, a real engineer, trained in college even, and he couldn't beleive what he read on this post. Let's face it, it's just a stupid question on a damn thermostat, let's take it to the moon and back, when the OP asked a simple question.
My invite for late July/early August still stands, bud
BBTank
I started this thread to try to find some opinions about max water temp a motor (mine in particular) should be run. And Thermostat DOES have a lot to do with this. Your Thermostat sets your lowest operating temp. Your highest is determined by radiator, water pump, ambient temp, etc. If with a 160 thermostat the car runs at about 160 then increasing the temp the thermostat opens will adjust the operating temp accordingly.
Please don't argue about opinions and experience and start calling people out. That was not the purpose of this thread. I think you guys can find a different place to hang out if you want to act like 7 year olds.
Thank you to those of you that have left valuable feedback.
