Yes the 79 and 80 rear ends are very different. The 79 used an iron pumpkin and the 80 and 81 used an aluminum Dana rear. Also the mounting is different. The 80 used and aluminum bat wing. I don't have any pictures but they are quite different.
Thanks Gordon,
In my ignorance what is an Iron Pumpkin and an Aluminium Bat Wing?
Go to Paragon's web site and download their catalog. They have good diagrams of each style. http://paragonreproductions.com/
This is a forum members car with a C4 rear end that is similar to the 80-82 rear end
and here is a 3D model of the 79 and earlier style.
Good pictures above. The bat wingyou can see in the upper picture. It mounts to the frame and mounts the rear to the bat wing. It is what hold the rear pumpkin to the frame. The iron pumpkin refers to the 79 and earlier center section. This is what holds all the gears. It is the center section. The 80-82 cars were aluminum and were weaker units than the older iron units.
