Bypass the heater core?
Old Dec 9, 2008 | 04:04 PM
shank0668's Avatar
shank0668
Default Bypass the heater core?
Should i do it because my 78 gets hot as heck on your feet. lol sometimes I wish it was about 0 degrees out because it so hot.
Old Dec 9, 2008 | 04:15 PM
Durango_Boy's Avatar
Durango_Boy
The heater core may not be the problem but the valve that is supposed to close off the hot fluid might not be working. It's vacuum controlled. The selector may be bad, as well as the valve may be stuck open. Something to look into before bypassing it.
Old Dec 9, 2008 | 04:31 PM
Bowerss2's Avatar
Bowerss2
if it is really that bad then i think this may be the problem, had this go wrong in a biplane i was flying, i thought my feet were on fire by the time i landed
Old Dec 9, 2008 | 05:07 PM
ripforrey's Avatar
ripforrey
check the valve first, at least it's not too hard to get at.
Old Dec 9, 2008 | 06:28 PM
Paul L's Avatar
Paul L
Replace the valve and no coolant will get to the core.
To Bypass the heater core?
