Blinker is sloooooooooooooow
Old Dec 10, 2008 | 07:51 PM
Motor City Vette's Avatar
Motor City Vette
Default Blinker is sloooooooooooooow
My blinker is super slow, is this most likely the relay?
Gracias
Old Dec 10, 2008 | 08:35 PM
Sayfoo's Avatar
Sayfoo
Usually it is a burnt out lamp. If not, then generally the flasher.
Old Dec 10, 2008 | 10:18 PM
Richard Cooper's Avatar
Richard Cooper
Check your light bulb.
Old Dec 10, 2008 | 10:39 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Replace the flasher, check the bulbs first
Old Dec 10, 2008 | 10:47 PM
...Roger...'s Avatar
...Roger...
with all above but a poorly grounded bulb will do the same thing.
For the flasher to blink it needs the load of several bulbs-the more bulbs the faster the blinking------less bulbs = slow blinking
Old Dec 11, 2008 | 09:45 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree with all of the above. Just wanted to add if all else fails: If your charging system is not up to snuff one of the signs of a drained battery is slow blinkers. I had this problem recently. Turned out to be a bad connection to the back of the alternator. Even when running, the car was drawing directly from a weakened battery because it wasn't charging and my blinkers were very very slow. Fixed the wire, charged the battery and the blinkers are at the right speed now.
To Blinker is sloooooooooooooow
