76 brake caliper replacement
Old Dec 11, 2008 | 12:17 PM
cvttejim's Avatar
cvttejim
Default 76 brake caliper replacement
I have a 76 coupe with only 38k miles, gets driven very little but I am planning to drive more often. I am planning to redo the brakes/calipers. my thoughts are to replace calipers with rebuilt o-ring type. Any comments/recommendations/suggestions will be most appreciated. cvttejim
Old Dec 11, 2008 | 12:36 PM
20mercury's Avatar
20mercury
Default 76 Brakes
Just did mine on my 76 and replaced all four calipers, master cylinder and front rotors (back were ok). also did the parking brakes shoes (now qualified to do brain surgery by the way )
I bought rebuilt calipers and rebuilt master cylinder from national auto chain with lifetime warranty and stainless steel liners. Pretty cheap compared to others, shop around !!! My professional mech buddy said to go with stainless steel liners for calipers and ss brake hoses too. The original calipers tend to rust in the bores unless you bleed your brake fluid frequently and stainless steel resleeve is the way to go. I think the C3 caliper design is not the best so no calipers are supposed to be a forever fix as I understand it. Brakes work great now!
Good luck!
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Sounds like a winner.
Old Dec 11, 2008 | 12:42 PM
GTR1999's Avatar
GTR1999
If you only have 38k miles then chances are your rotors are still riveted in place and in good shape. If so check the runout and if it's under 005 then you don't need o ring calipers. Clean up the rotor surface with 100 grit D/A, install the SS lined lip seal calipers, replace the rubber hose at all 4 corners and don't forget the front copper washers, use new organic pads and DOT3 BF, use a Motive bleeder and you're done.
Old Dec 11, 2008 | 04:19 PM
ugadawg77's Avatar
ugadawg77
Default newbie with a 78...
Just did the oring rebuild kit on the back as you are describing...went great...hit a small snag with a frozen brake line, but was able to get all four orings & seals replace on each side (LH & RH) without much trouble. I now have the front brakes off & ran into the same problem with the brake line. Rather than risk stripping or ripping the line to hose bracket off the wall, I just simply unscrewed the hose line from the caliper, by rotating the caliper inside the wheel well. Not very hard & plenty of room, just be careful not to kink the hose.
Now once I got it off & disassembled...that's another story..
I have had major trouble finding the rebuild kit for the front that the o-rings fit. The ones I used on the back from Advance auto (Tru-Torque), fit perfectly on the back, but are too wide & won't seat in the piston hole on top of the SS Sleeve as they should. I am looking now for another brand to try on the front ones...if you come across one that works, please let me know!
Old Dec 11, 2008 | 06:33 PM
Scott Marzahl's Avatar
Scott Marzahl
I've used the O ring kits from Vette Brakes and Lonestar, both great stuff. You'll notice a big difference between the seals from these and the cheaper kits.
Old Dec 11, 2008 | 07:13 PM
Steve COSD's Avatar
Steve COSD
This is the way to go. If your car sits the seals on the piston relaxes and that's when it will leak. The O ring solves the issue.
Good Luck
Steve
Old Dec 14, 2008 | 12:53 PM
jb78L-82's Avatar
jb78L-82
Good luck!
My 4 SS calipers from VBP have been on the car for 23 years with no leaks and the car is driven very little which normally is not good for the calipers. Terrfic product and design from Vette Brakes and Products!
To 76 brake caliper replacement
