Alternator whine
Leave the amp ground at the battery. It's better than the frame or anywhere else on the car.
Is the new alternator an aftermarket high output alternator? Typically those higher output SI alternators are known for low output at idle. Their new guts that make them put out more power also mean they put out less power at idle...sometimes even less than stock.
I might also suggest you remove the alternator and take it to a shop that specializes in repairing starters and alternators. They will be able to test it. If you don't have a shop like that take it to a chain parts store as they can usually test them for you too. Make sure it's someone you trust knows how to properly operate the machine.
Thanks for all the help.
