Do I need this thing?
Old Dec 13, 2008 | 04:06 PM
Droshki's Avatar
Droshki
Default Do I need this thing?
So I tore town my 355 and I'm building a 383. This thing, apparently some sort of push rod retainer, was in the valley of the old engine. Anybody ever seen one of these? Do you think its worth transferring over?
Old Dec 13, 2008 | 04:09 PM
sweethence's Avatar
sweethence
From: Wilmington DE, Drive it like you stole it, 68 327 4 speed coupe
looks like a heat sheild to me, held in place by the lifter valley and the base of the intake,
up to you But i say not required fro normal applications
Old Dec 13, 2008 | 04:12 PM
Droshki's Avatar
Droshki
Yes, the edge of the heads caught those clips and held it down.
What are we shielding from heat?
The motor did have (and the new one will) a roots type blower.
Old Dec 13, 2008 | 04:24 PM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
That's a lifter valley baffle. Keeps hot oil from splashing onto the manifold bottom. Also might keep some oil splash out of the rockers.
I used one when I had my PCV valve in the back of the intake. Worth keeping? Can't hurt anything...
Old Dec 13, 2008 | 04:36 PM
tfi racing's Avatar
tfi racing
If you have it,use it, supposedly it will keep the intake a bit cooler.
Old Dec 13, 2008 | 04:45 PM
Droshki's Avatar
Droshki
Thank you all. I will clean it up and put it back into the new engine.
Anyone wanna take a swipe at my question about the plugs in the block a couple threads down?
Old Dec 13, 2008 | 07:04 PM
TimAT's Avatar
TimAT
Some of those sheilds, in addition to keeping hot oil off the bottom of the intake, had the added little option of keeping the lifter IN place in the event of a valve train failure. That kept the engine from suffering a total oil pressure loss.
Old Dec 13, 2008 | 07:42 PM
Gordonm's Avatar
Gordonm
The plugs in the lifter valley limit the oil dripping on the crank. If the crank is spinning at 6000+ rpm and oil is running onto it the crank will have to push the oil out of the way. Limiting the oil on the crank will get you a couple of HP in the upper rpm.
To Do I need this thing?
