What's normal for Big Block water temp?
Old Dec 15, 2008 | 02:15 PM
Augustus's Avatar
Augustus
Default What's normal for Big Block water temp?
Just curious.. What temperature would be for normal operating range for a Big Block?
I have a 70 454 LS5, and Just would like to know. Operating stats
Correct Water Temp.. What's the high to be safe? 200?
Also normal Oil pressure. PSI
Old Dec 15, 2008 | 07:16 PM
itsabigblock's Avatar
itsabigblock
my car runs about 190,anything past the 212 mark and you got problems.oil pressure when I first start it the needle is pined,after it warms up 60 t0 70 psi
Old Dec 15, 2008 | 07:37 PM
sly vette's Avatar
sly vette
The temp in ANY vehicle is regulated by the thermostat if it is working properly.
A 190* t-stat should run at approx 190.
Sly
Old Dec 15, 2008 | 08:42 PM
Sayfoo's Avatar
Sayfoo
My 69 bb runs 200-230, depending on the outside temp and whether moving or stopped. I have a 180 stat.
My oil pressure when wam is about 35 at idle, and up to 60 while running at speed.
Thermostat determines minimum operational temp. The max temp is determined by the engine itself, the cooling system, air flow, etc.
Old Dec 15, 2008 | 09:51 PM
Augustus's Avatar
Augustus
Thanks guys,
So 200 - 212 or to a Max of 220-230 depending on outside temp.
So at just under 200 it should be okay.
And Oil pressure 35 - 60 psi
Thanks good to know.
Old Dec 15, 2008 | 10:29 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
my 69 427 never gets up to 200 it's right about 195. I also have a 160 thermostat
Old Dec 16, 2008 | 12:03 AM
sly vette's Avatar
sly vette
You are correct....Stat opens at min... Sorry if i confused anyone.
Sly
Old Dec 16, 2008 | 12:12 AM
early shark's Avatar
early shark
My 3 '70 LS5's and '71 LS5 typically ran around 210 most of the time and 225 or 230 on a hot day and stalled in slowing moving traffic. I live in California and the average temperature is usually around 79 in spring, summer, fall.
Old Dec 16, 2008 | 01:03 AM
elle88's Avatar
elle88
guys ,
the values are those indicated by the temp gage. but make a test with an electronic temp gage directly on the engine and check if the reading matches with the cockpit gage.
On both my vettes ( 79 350 and 69 427 ) there was a large mismatch
Old Dec 16, 2008 | 04:41 AM
Ironcross's Avatar
Ironcross
No higher than a small block of the same year. Those of non emission controlled engines will run cooler than those computerized and with sensors to control engine performance to meet either State or Federal standards.
To What's normal for Big Block water temp?
