Power steering control valve proplem
Old Dec 16, 2008 | 08:46 PM
Tecdiverfl's Avatar
Tecdiverfl
Default Power steering control valve proplem
My control valve was leaking on my 70. It was 7 months old and the guys from Zip shipped be a replacement ASAP. The problem is when I thread it on the center link I can not get to to thread any further then about 8 turns. The old one unscrewed with no problem. I have even put a little grease on the threads. I even tried removing the bolt from the control valve. Any one have any suggestions of what is my chance the replacement valve may be out of wack?
Old Dec 16, 2008 | 08:48 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
Do not whack it !
Bolt must be removed to thread On , ... and off,
or you damage the threads ! 69Vett
Old Dec 16, 2008 | 08:51 PM
Unforgiven1's Avatar
Unforgiven1
You may have to use an assist to get it threaded on. I have used a punch inserted in the pinch bolt hole in the past and it works well. May just have a burr in the threads that you can't see.
Old Dec 16, 2008 | 09:00 PM
...Roger...'s Avatar
...Roger...
Take a chisel and drive it gently between the ears where the pinch bolt goes.Keep the punch out at the ears.This will spread it a little and usually lets it thread on.Also check as others said for a burr in the threads at the split of the threads.
Old Dec 16, 2008 | 09:07 PM
Tecdiverfl's Avatar
Tecdiverfl
Once I threated it as far as I could turn it I tried to get the bolt in and could not thread it. I wonder what the chances are the threads go be off on the new valve
Old Dec 16, 2008 | 09:39 PM
76projectstingray's Avatar
76projectstingray
I just had the same problem with mine. its a lonestar rebuilt from Zips.
I had to keep threading it on and off getting it on a little farther each time. You do need to get the pinch bolt off before you try and thread it on. then line the pinch bolt up with the flat spot on the link bar. I was almost going to use a pipe wrench on it ,but that would have marred it up. I did use Rubber strap wrench on it to wrap around it and get the leverage to turn it on tight.( I think the rubber strap wrenchs are used for plumbing?)
Old Dec 17, 2008 | 02:03 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Old Dec 17, 2008 | 02:59 PM
68/70Vette's Avatar
68/70Vette
I fought this problem on installing a rebuilt control valve on my 68.
The rebuilt valve female threads (1 /16 inch threads) had some gunk of some sort in them. I cleaned them out with a dremil wire brush and eventually was able to wrench the control valve on.
For my 70 install, the relay rod theads were scruffed. I bought a die and cleaned them up. I think the size in 1 1/16 18 NF. This is an unusual size, I had to get one from a machinests supply shop. Cost was ~$28.00. Similarly, if you have damaged threads in the control valve, a solution is to buy a tap and clean them up.
Old Dec 17, 2008 | 03:27 PM
...Roger...
Just in case you decide to do what I suggested I went out and took a pic so its more clear as to what the chisel is going to do and how to drive it in.Sorry the pic is not real good I couldnt stop shaking,its frigging cold here.This should make it easier to thread on.
Old Dec 17, 2008 | 03:48 PM
Tecdiverfl's Avatar
Tecdiverfl
Thank for the help. I will play with it tonite
Marty
Old Dec 17, 2008 | 07:43 PM
David Jackson's Avatar
David Jackson
The new one should screw on as easy or hard as the old one come off.
I had the same problem from Mid America..Old one came off just fine new one screwed on about 5-6 threads..Found gaulded threads on new valve.Called Mid America and complained about new valve and bad threads and no point in rebuild process to varify good threads.They sent me another one that screwed on as easy as the old one screwed off.
Old Dec 18, 2008 | 08:47 AM
Tecdiverfl's Avatar
Tecdiverfl
I tried again last night. The only way this thing is going on with a pipe wrench. I am calling ZIP today as it lookslike the threads on the valve do not line up after the slit
Old Dec 18, 2008 | 01:27 PM
Tecdiverfl's Avatar
Tecdiverfl
Just spoke to Zip they agree it should not be that difficult and are shipping me a replacement. Zip happens to be great with replacements
Old Dec 18, 2008 | 01:34 PM
1nicecorvette's Avatar
1nicecorvette
sounds it! threes a charm i guess! must be more then just you who have had the ZIP valve problem.
Old Dec 18, 2008 | 08:40 PM
Tecdiverfl's Avatar
Tecdiverfl
Most of the valves people sell are rebuilt from LoneStar so I can't fault Zip.
To Power steering control valve proplem
