C3 plug change write up?
Old Dec 18, 2008 | 12:02 PM
Quicktime_GT's Avatar
Quicktime_GT
Default C3 plug change write up?
any good articles over changing plugs in a c3?
Old Dec 18, 2008 | 12:17 PM
Durango_Boy's Avatar
Durango_Boy
Not that I know of, but remember that the ones you have trouble with from the top might just be easier from under the car. You get a whole new set of angles from under the car.
Old Dec 18, 2008 | 12:26 PM
Jeff_Keryk's Avatar
Jeff_Keryk
I use a little anti-sieze on the threads, and one of those rubber tube installers. Easy-peasy.
Old Dec 18, 2008 | 12:35 PM
20mercury's Avatar
20mercury
Default Another thought too.
Just did this on the 76 and got 2 & 4 under the a/c compressor from inside the wheelwell.
Also checked the compression while putting in new plugs.
Old Dec 18, 2008 | 07:12 PM
Paul L's Avatar
Paul L
This is so true, through the mud flaps. Rachet handle, extension, u-joint, extension, socket. Have fun.
Old Dec 18, 2008 | 09:51 PM
baxsom's Avatar
baxsom
since i took the non functioning compressor out, plug changing has been a lot easier
To C3 plug change write up?
