How fast will a C3 go?
Old May 8, 2010 | 01:40 PM
  #341
RonnyV1980's Avatar
RonnyV1980
You are going to have to make sure that you have a real "tight" car when you do try this. Any play anyware will only be magnified at these speeds mentioned. Another thing to be very sure of is what have you done to get your ride stopped when you need to? I hear a lot of people adding things to go faster, and don't upgrade anything in regards to slowing down faster. Whenever anybody asks me what I've done to go faster, I tell them I got better brakes.
Old May 8, 2010 | 02:13 PM
  #342
aaroncorvette's Avatar
aaroncorvette
Good point about the brakes, the brakes on mine are stock except for stainless pistons and they are fantastic, i don't see how i could upgrade them for street use, anyone else got great stock(ish) brakes?
Old May 8, 2010 | 02:16 PM
  #343
straub18045's Avatar
straub18045
i upgraded mostly everthing except for brakes, i did put in stainless steel flex lines and all new/stock calipers and a master with dot5. they stop me fine at the end of the strip. but could see some advantage of a brake upgrade but for the price ill just put more $ into the motor
Old May 30, 2010 | 07:38 PM
  #344
MattP51's Avatar
MattP51
I don't see why a c3 can't do 225. Hold on, I'm going to go try. Will report back.
Old May 30, 2010 | 07:48 PM
  #345
Ed Campbell's Avatar
Ed Campbell
Some parts may reach that speed when the whole car explode getting there. Ed
Old Jun 1, 2010 | 10:41 PM
  #346
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Anything actually still considered a Corvette could not reach 200mph if thrown out of an airplane
click below for proof
http://wiki.answers.com/Q/What_is_th...ocity_of_a_car
Now....on the other hand we have run over 200mph at Daytona.....but this car has only a handful of actual Corvette parts, advanced aero, and at that time over 700 hp @ 2564#.
Oh and ya we even had good brakes
Old Jun 2, 2010 | 10:46 AM
  #347
wan2run's Avatar
wan2run
LOL, off a cliff?
Old Jun 2, 2010 | 12:48 PM
  #348
mxscooter's Avatar
mxscooter
I just laughed part of a cheese sandwich out my nose thanks
Old Jun 2, 2010 | 05:13 PM
  #349
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I don't think you'll ever be back here after that try on a C3!
Old Jun 2, 2010 | 05:28 PM
  #350
MrJlr's Avatar
MrJlr
Einstein states that as speed (or velocity) incresses, so to does mass (weight). For instance, a car going 100 mph hits a wall much harder than a car going 10 mph because effectively - the car weighs more.
Soooo....the faster you go - the more you weigh...the more you weigh, the more POWER it takes to go any faster....and that effect just multiplies.....
Anyway.....LOL ! 200 mph takes a darn lot of power !
And ya better have brakes, wheels, tires, suspension, etc to handle that too !
Old Jun 3, 2010 | 07:56 AM
  #351
73-84 IMSA Widebody
If you click the link in my post above....I bet you will be shocked to see that a car, in an aerodynamic nose down position will free fall at about 90 mph. What slows it down...the friction of the atmosphere and the friction increase logrythmically as speed increases. It is 10 times harder to gain 1 mph at 100mph than it is at 70mph....and 50 times harder at 150mph. speed=money and big speed=big money
Old Jun 3, 2010 | 08:58 AM
  #352
mrvette's Avatar
mrvette
TWO WHICH I may add again.....
do not believe your speedo/tach/mph-rpm calculations......
Believe your GPS/Garmin.....
Old Jun 3, 2010 | 04:55 PM
  #353
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I was under the impression that horsepower requirements went up as the cube (exp3) of the speed. That would get you:
(100/70)exp3 = (1.43)exp3 = 2.92, or approximately three times the power necessary at 100mph compared to 70mph.
(150/70)exp3 = (2.14)exp3 = 9.84, or about ten times the power necessary at 150mph compared to 70mph.
Someone please correct me if I'm mistaken.
Old Jun 3, 2010 | 05:13 PM
  #354
roscobbc's Avatar
roscobbc
Interestingly (and this was on a private road - so perfectly legal )
car hit the rev limiter (set at 6200 rpm) in 3rd - a little surprised didn't expect it to get there so quick - calc with 285/40/18 tyre and 3.08 says 130 mph - so IF it pulls 6200 rpm in 4th that means 165mph (I did say IF!) so a lower numerical axle, overdrive gearbox or 7500 rpm would be needed for the 200 mph barrier - presuming of course the car remains on earth
Old Jun 3, 2010 | 06:31 PM
  #355
OregonVette80's Avatar
OregonVette80
before my suspension upgrade (and tremec 5 speed upgrade), at the end of the straight at PIR I would hit 120mph and my 1980 felt very spongy and "curious" at that speed.
NOW: insert $ --- New bushings, Bilstein HD, 550# front, 360# rear, new steering box, pump, front suspension work, 5 speed tremec and racing slicks later...
I have bumped it to 125-128mph and the car feels 100% positively better.
LASTLY (as no one has mentioned) I had my entire brake system re-done, Hawk HP+ pads and Autotech HP blue Brake fluid DOT4.
I want to make sure I can stop more than I wanna go forward.
Old Jun 4, 2010 | 12:22 AM
  #356
richiev88's Avatar
richiev88
My first C3 a 1970 with about 350hp, 15 inch wheels, std shocks.
I got up to about 140mph ( followed by a freinds ferrari 512 with a more accurate speedo) , we were on a back country road (which seemed flat at legal speeds), but so so at 140mph, car felt very unstable, I got a big "tank slapper on" managed to slow and gain control...never tried it again.
But up to about a 100mph on the motorway seemed fairly safe
Old Oct 23, 2010 | 10:38 PM
  #357
c3corvette77's Avatar
c3corvette77
i don't know if anyone chimed in with this but i'm not going to dig for it either. in aviation, my chosen maledy, aerodynamics tells us that the horsepower requierment goes up as the square of the speed. if you want to go twice as fast you need 4 times the horsepower. say 100 hp gets you 100 mph, want to go 200 you'll need 400 hp. now that's aerodynamics, cars have road friction, driveline losses etc, but you're looking at needing 4 times what you got to go twice as fast....
To How fast will a C3 go?
Old Oct 24, 2010 | 01:00 AM
  #358
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I can't recall if anyone else made that point before, but you're right on the money there. FWIW, models I've simmed (sp?) indicate it should take ~600-650 HP to push a properly geared and trimmed C3 to 200, fastbacks requiring a bit less than earlier ones. ...tho I haven't put that theory to the test.
While on the subject, does anyone know anything more about Sundowner's incident on the salt than mentioned in December Hot Rod?
Old Feb 26, 2011 | 09:39 PM
  #359
poz235's Avatar
poz235
2nd Gear
I've had my '72 (stock 200hp) up to a garmin verified 127, and that was all it had to give (it went a bit faster new, or so my dad claims), and to hit 200mph would require far more than an extra 200hp due to both drag, lack of downforce and weight. I have the 400hp engine from a Ferrari 360 in my Quattroporte and that will max at 171, and the Ferrari 360 won't even do it. Actually, very few cars will.
Also, on Top Gear, Clarkston set the record for a production car at 176 in the ZR-1, which, even with al its power, will top at 205.
Hitting 200mph is something very few cars do. Only the last generations of Ferrari's (the 599, 458 and Enzo) will hit it, along with others like the Ford GT 40; Lambo LP640, Bugatti Veyron / Veyron SS, Koenigsegg CCX; Pagani Zonda; Maserati MC12 and Mercedes McLaren SLR. All of these cars are much slippier in air than a C3, have about three times the power and weigh far, far less.
That being said, would it be possible to make a C3 hit 200? Yes; however, I would not want to be in that car when it's making that run. That frame and design is just not made for that kind of speed.
Old Feb 26, 2011 | 11:21 PM
  #360
PeteZO6's Avatar
PeteZO6
Go back and read post #27. On the third page of the magazine article it says that Sundowner ran at Bonneville at 240.728mph in 1981. it was running a twin turbo big block. Sundowner is a stock body 1968 Corvette convertible with a hardtop. That seems to answer the OP's question, How Fast Will a C3 Go? pretty well.
Pete
