7.5 mpg...?!?
Old Dec 19, 2008 | 04:55 PM
SteyrAUG's Avatar
SteyrAUG
Default 7.5 mpg...?!?
Well I just did the math and that is all I'm getting with my 1980.
After some research I found that I should expect about 16 MPG. Obviously something is wrong.
What do I need to look for to correct things?
Old Dec 19, 2008 | 05:39 PM
Attfay Elleybay's Avatar
Attfay Elleybay
Start with a tune up. Spark plugs, wires, cap & rotor. & air filter.
Old Dec 19, 2008 | 06:11 PM
mrvette's Avatar
mrvette
Finish with rebuilding or getting the Qjet carb sent off and rebuilt correctly....then to go through all the obvious setups on timing/etc....need know the miles on the car before more suggestions....also about the driver train....tranny/rear diffy ratio...all these things on a for sure basis....old cars have lotsa hotrodding done over the years/decades...so all this need be proven to know for sure where to go....at 7.x mpg it's really poor, I would go for the Qjet along with the above tune up's....
Old Dec 19, 2008 | 07:45 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Personally I would look at some things before I started tearing anything apart.
There are some basic questions I would look for.
Do you smell any fuel when you start the car, shut it off or while driving it?
How is the car performing?
Do you know what rear end is in the car?
Remove the air cleaner, do you see fuel stains on the intake. Carb leaking
Look under the rear of the car on the exhaust, do you see any brownish color stains? Fuel Tank leaking.
Inspect the area around the fuel pump for a leak.
Is there any smoke coming out of the car?
Pull the plugs and inspect them. See if you have fuel fouled plugs, carbon on the tips, brunt electrodes etc. Read the spark plugs, they will always tell a tale.
Eliminate the obvious first before you start pitching money out the window.
IMHO,
Willcox
To 7.5 mpg...?!?
