71 a/c heater control on consol
Old Dec 24, 2008 | 08:06 AM
larry hinterman's Avatar
larry hinterman
Default 71 a/c heater control on consol
Orginal four seasons control for a/c and heater.
The red position indicators under the glass in the control have come loose. When you roll the wheels the indicators do not move.
I have removed the control from the consol. On the bench I took out the four bolts/screws and I cannot get the top off to look at how the indicators are attached.
1. Are there other fasteners?
2. Is it possible to repair this problem?
3. How can I repair or replace the problem?
Thanks,
Larry
Old Dec 24, 2008 | 09:15 AM
boat196's Avatar
boat196
Search in the general section,for restore/rebuild ac heater control. Well detailed.
Bob
Old Dec 24, 2008 | 11:36 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
For unknown reasons, I am thinking there are two, tiny, Phillips head trim screws on the top of the bezel. Those could be a '68 only thing.
http://www.corvettemagazine.com/2001...-panel/ac1.asp
Old Dec 24, 2008 | 11:43 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
This may help you too! http://willcoxcorvette.com/repairand...lp.php?hID=189
The problem with the needles. . .they get brittle. When this happens, the little ears that hold the needle on the string break. You can glue them to the string if you needed or we have them used in stock.
Here is the link to all the control used parts we have available at the moment. http://willcoxcorvette.com/advanced_...eywords=heater
Happy Holiday's
Willcox Inc.
Old Dec 24, 2008 | 01:30 PM
larry hinterman
Thanks a million! That is a great article.
Larry
Old Dec 24, 2008 | 05:11 PM
0Willcox Corvette
Former Vendor
Thanks Larry, I just re-read it and found about 8 typo's. It needs to be revised. Maybe a good project for tomorrow afternoon.
Willcox.
To 71 a/c heater control on consol
