1980 tach question
Old Dec 9, 2010 | 10:19 AM
Rickyh's Avatar
Rickyh
1st Gear
Default c3 tech
Need help on my 80 tech. when tech works oil perssure does not (this was first problem about 3 months ago) now tech works but car wont run. when i turn on the key needle goes down to 0 and when i crank the car needle jumps up, but hers the thing, the tech wire is not even connected to the distribtor?????. check the profmance modular, it was dead and changed it but still the same problem. the only time the car would run was when the tech was dead and did not work, but the car did run?
