turn signal problems
Old Dec 26, 2008 | 12:36 PM
ripforrey's Avatar
ripforrey
Default turn signal problems
On 76, 350, ac, at.
I changed the bulbs in the tach & speedo also replaced bad hl switch (switch was good, the vac. connection on the side was bad). tested everthing and worked fine.
Now when I turn on hl's I get weak light on both turn signals. The signals work and hazards work. All the other lights work as they should.
Although the turn signals do seem to blink slow.
I'm looking at all connections for the 2nd time.
Any ideas would be appreciated.
Old Dec 26, 2008 | 03:13 PM
G dad's Avatar
G dad
From: THE OLDER I GET THE BETTER I WAS! NORTHERN ONTARIO
Our cars are real bad for ground problems...re trace your steps & look for grounding problems..loose wires...bad connectors stuff like that.
Old Dec 27, 2008 | 12:55 PM
ripforrey's Avatar
ripforrey
Thanks, I isolated the problem in the wiring harness in the tail light assembly in the back of the car.
Old Dec 27, 2008 | 04:39 PM
G dad's Avatar
G dad
Awesome!
To turn signal problems
