help identifying wire 1978
Old Dec 26, 2008 | 02:29 PM
blctalon's Avatar
blctalon
Default help identifying wire 1978
The interior is out of the car and I'm running new speaker wires "while I'm at it." I have the nest of speaker wires out that are all marked FL, FR, RL, RR all out of the way so I can see what I'm doing. I'm assuming these wires are original and appear to complete the 4 original speaker install that was in the car.
So that being said, I'm looking down the driver's side floor and there's a black plastic wire loom with a bunch of wires going to the rear driver's side of the car. A small ways up the fender hump 4 wires are protruding out of the loom and have spade connectors on them. 2 of the wires are blue and 2 of the wires are black. The black pair are both coming from the back of the car somewhere and the blue pair are coming from the front. Each blue has a black taped to it, so essentially there is a 2 blue/black pairs of wires with connector spades on them, but there's nothing to connect them to. Anyone have an idea what these are for? Is there a relay or module of some sort missing back here where these things plug in?
Im fairly certain these aren't speaker wires because they're not long enough to reach the 2 speaker compartments in the back. And I forgot to trace them when I had the dash off.
Old Dec 26, 2008 | 03:15 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
Are you saying these wires are simply run under the carpet on the driver side floor? Not something the factory would do. Sound like something aftermarket as black wires are always grounds from the factory.
Old Dec 26, 2008 | 09:22 PM
19LEW71's Avatar
19LEW71
Could be for the door switches on both sides that would trigger your alarm.
Old Dec 26, 2008 | 10:04 PM
...Roger...'s Avatar
...Roger...
If the blue is Lt blue then it might be the wires that go up to T top alarm switches at the back of each top.
Old Dec 26, 2008 | 10:16 PM
KapsSA's Avatar
KapsSA
If it's the harness that runs along the inside rocker by the door,
I was picturing wires under the seat.
This help any? Note view B....
Old Dec 27, 2008 | 12:19 PM
blctalon's Avatar
blctalon
Yes they're light blue. Are these the Ttop alarm thinger and if so, it appears they're disconnected, should I just tie them out of the way and get rid of the spade connectors so they don't touch anything?
Old Dec 27, 2008 | 01:40 PM
KapsSA's Avatar
KapsSA
Most 78s don't have alarm protection for the tops. If your VIN is before 25000(or 4600 Pace Car) yours won't have it. The wires are probably just there and not utilized just like other options not on a particular Vette, the wires may still be present in the harness.
To help identifying wire 1978
