1982 Collector Corvette, won't start
Old Dec 28, 2008 | 06:45 PM
Rob Lovedee's Avatar
Rob Lovedee
2nd Gear
Default 1982 Collector Corvette, won't start
Hi, I have an 82 Collector series which was running & driving perfectly until I was driving in a bad electrical storm when lightning struck right next to us, the car stopped & everything was dead except for the headlights, both high & low beam are the only thing that works. I have checked all fuses , no problem, it may be a coincidence as I hit a bump in the road around the same time.
Has anyone any ideas? where should I start looking? could it be the computor, I am in Australia so I dont want to buy a computor from the U.S. if there may be a simple explanation.
Any information would be greatly appreciated.
Thanks,
Rob.
Old Dec 28, 2008 | 09:12 PM
dannyman's Avatar
dannyman
Start with the basics. I would check all the grounds then fusible links. Start at the battery and work your way through the electrical system logically to locate damage.
Do you have good electrical schematics?
Old Dec 28, 2008 | 09:36 PM
terry82's Avatar
terry82
have you got spark /have you got gas ?check your fuses.
Old Dec 29, 2008 | 12:37 AM
aussiejohn's Avatar
aussiejohn
Default Welcome!
Rob,
Welcome to the Forum. Tell us where you live and one of our antipodean members may be near enough to come over and look at it. I am in Highett, Melbourne. Ring me 03 9502 3227 if you wish.
Regards from Down Under.
aussiejohn
8 months to go
Old Dec 29, 2008 | 12:27 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Rob Lovedee
...could it be the computor...
Yes. It could be fried. Can you read any codes out of the computer?
Old Dec 30, 2008 | 11:08 AM
DTbull's Avatar
DTbull
sounds like your ecu is fried,,, happens here in florida on the newer cars durring lighting storms,,,
Old Jan 4, 2009 | 04:59 PM
Rob Lovedee
2nd Gear
Thanks for your replies. I Also think that the computer could be fried.
I don't have any wiring diagrams but all the fuses are OK. Could anyone tell me the location of the fusable links?
Old Jan 4, 2009 | 07:30 PM
dannyman's Avatar
dannyman
Starter, alternator, fuse panel typically. Sometimes at the battery.
The wiring appears to be larger at the link, but in fact is smaller wiring wrapped in insulation which gives the appearance of larger wiring. When you locate one link you will now what they look like, making it easier to locate additional ones. They are normally exposed wires (not wrapped in a loom). A burnt link would show signs of expansion on a spot within the insulation, if not complete burn-through.
Old Jan 5, 2009 | 08:39 PM
Dirtbuster1's Avatar
Dirtbuster1
The power to the 82 is fed through the starter. There are 2 fusible links there. Positive wire from battery goes directly to the starter. If your gauges or other interior lights are not working start there. Just to be on the safe side, make sure your main grounds are connected.
Old Jan 6, 2009 | 05:25 PM
terry82's Avatar
terry82
your problem is probably some were else but ,i would check the wiring harness connector that plugs in behind the passenger side engine head .
To 1982 Collector Corvette, won't start
