power steering pulley install
Old Dec 28, 2008 | 11:57 PM
bms1973's Avatar
bms1973
2nd Gear
Default power steering pulley install
I need to install my pullley onto my power steering pump without damaging anything. Any Tips? It's a cast pulley. looks like a three spoke wheel.
Old Dec 29, 2008 | 08:18 AM
Jim Shea's Avatar
Jim Shea
I assume that you have a 1973 Vette and a 1973 vintage power steering pump. All GM power steering pumps up through 1974 had a 9/16-18 UNF male thread on the end of the driveshaft. The driveshaft also had a 1/8 X 1/2 inch Woodruff key. You matched the keyway in the pulley to the Woodruff key and tightened the pulley onto the shaft with a nut (60 ft-lbs).
I thought that the pulley nut was torque prevailing. However, this nut on the Zip Store websight does not appear to be torque prevailing.
http://www.zip-products.com/Corvette...CE68E6898C2F67
All GM pumps (1975 forward) had interference fit driveshafts and pulleys. They do not interchange with the nut retained pumps and pulleys.
Jim
Old Jun 27, 2009 | 09:29 PM
slewfoot1956's Avatar
slewfoot1956
St. Jude Donor '14
Default 82 Power Steering Pump
Are there any step by step instructions for idiots-removal and replace of the pump? Pics?
To power steering pulley install
