Tires. Front and Rear???? help
Old Dec 29, 2008 | 09:01 PM
78vette78's Avatar
78vette78
Default Tires. Front and Rear???? help
I was about to order my tires today 255x60x15 all around BFGoodrich
BUT I was thinking that will it look better if it get 255x60x15 FRONT and 255x70x15 for the REAR
Im sure the 255x60x15 will fit the FRONT.
Im not that sure if 255x70x15 fits the REAR and will it look better??
Please help. I ned tires ASAP. My tires are about to pop very soon. I dint know that buying tires can be this hard.
Old Dec 29, 2008 | 09:21 PM
Grumpy 427's Avatar
Grumpy 427
Te 255/70 is 2" taller than the 255/60 and its going to be narrower as well A 275/60 is 1" taller and the 1"wider.aprox.
Old Dec 29, 2008 | 11:04 PM
78vette78's Avatar
78vette78
but is the 275/60 too wide for rear?? i dont want it to rub.
do u havea any suggestion frome me?? front and rear
Old Dec 29, 2008 | 11:35 PM
corvettedale's Avatar
corvettedale
Cruising
I have 255/60/15 on all four corners of my 78 and like the look.....If you wanted significantly wider tires on the rear, you could go with 295/50/15 with relatively the same tire height. They will stick out though....
Old Dec 29, 2008 | 11:51 PM
Grumpy 427's Avatar
Grumpy 427
My 1980 vette came with 255/60R/15 from factory all the way around. There are some guys here with 275/60 R/15 on the rear. On an 8" wheel they should fit without issue.
Old Dec 30, 2008 | 12:05 AM
corvettedale
Cruising
If just wanted a visual difference between the front and rear, you could run 235/60/15 on the front and 255/60/15 on the rear......
Old Dec 30, 2008 | 01:07 AM
78vette78's Avatar
78vette78
Thanks alot. u guys are the best.
Old Dec 30, 2008 | 01:29 AM
Inshakoor's Avatar
Inshakoor
I have an '80 with 255/60 15 in the front, and 275/60 15 in the rear with no problems running on the stock rims.
Old Dec 30, 2008 | 06:06 AM
jb78L-82's Avatar
jb78L-82
I had 255/60/15's for 25 years and a few months ago switched to SLP's 17 in rims with 255/45/17 ZR's in front and 255/50/17's in the rear. The reason I went with different size tires front and rear was because the 78-79 vettes have a rear biased squat look due to the body shape on the frame (not a sagging look due to a worn rear spring which can make the rear squat), assuming everything is in good shape. I also could not go to a smaller diameter rear tire without upping the rear ratio which is 3.70. I also have 1 in shorter coil springs in the front that along with the 1 in shorter front tires gives the car a slightly front biased look which I like very much. It looks like a vette should now. If you like this look of the early 70's vettes, I would go with 245/60/15's in the front and 255/60/15's in the rear perserving the axel ratio. Stay away from the 70 series profile if you can since these tires will make the tires more non performance than the 15 in tires available already are.
Old Dec 30, 2008 | 11:58 AM
WESCH's Avatar
WESCH
Hi
275 will fit in the back.
I have them on my 68 and they fit without any modifications, like parking brake bracket relocation or offset arms.
Rgds. Günther
Old Jan 2, 2009 | 03:57 PM
78vette78's Avatar
78vette78
Originally Posted by WESCH
Hi
Rgds. Günther
is that 275 60 15????
what abot 255 70 15 at the rear... do u think it will rub cause its taller or its should fit jus right??
Old Jan 3, 2009 | 01:35 AM
blckslvr79's Avatar
blckslvr79
As previously stated, you do not want to mix match 60 series and 70 series on the same car. It will look bad and drive bad. A 255 70 will be more narrow and taller than the 60 series on the front. Wide tires on the front with a narrow tire on the back will just look real bad and I do believe the 255 70 is too tall for the car (it's more of a truck tire). Some guys are running 255/60 up front with either 295/50 on rear or 275/60. The 295/50 is only about 1/2 inch shorter than the 255/60 so it is not really noticable, but it is much wider. Moving the parking brake is probably needed, but an easy mod. The specs say a 295/50 will fit the 8inch wide wheel, but it looks kinda ballooned out. 275/60 on the rear fit fine on the 78-82 Vettes and look the best in my opinon. I'd either run 255/60 all around or 275/60 on the rear.
I run 255/60 in front and 275/60 in back with no mods on a 79. Fits and looks great. Rear tires are about 1 inch wider and 1 inch taller than the front. Barely noticable, but beefy looking. With a 3:70 rear gear, the taller tire helped with cruising speeds also.
Old Jan 3, 2009 | 02:04 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i agree with the ballooning blacksilver. thats what im running 295/50/15 rear and on the front 265/60/15 with no mods and it does balloon but i like that.
Old Jan 3, 2009 | 02:19 AM
blckslvr79's Avatar
blckslvr79
It looks tough though!
I was torn between the 275/60 and 295/50 on the rear when shopping for tires too. If the rims where wider, I would have gone with the 295's.
Are your rear fenders flared??? Any pictures from the rear of the car???
295's look bad *** from the back!
Old Jan 3, 2009 | 02:43 AM
gingerbreadman1977
yes i sure do blacksilver. standard body .here is a rear view and a much more interesting side view.....
Old Jan 3, 2009 | 12:28 PM
spikebot 81's Avatar
spikebot 81
The tires look great..........and I really like the mod you've done to the drivers seat
Old Jan 3, 2009 | 07:46 PM
KTKelly's Avatar
KTKelly
The 255/70 is 2" taller than the 255/60 and its going to be narrower as well
The 70 series will be taller, but it will not be wider. 255 is 255 is 255...
To Tires. Front and Rear???? help
