The GM application was 55-79 Y (8 CYL.)Part number 3836755 It was called a Valve Stem Oil Shield. If you are talking about the part under the valve spring cap (the part the keepers hold down).
Willcox
Thank you for the help.
That was the part I was asking about.
If I buy Crane retainers , will they work with these shields?
Or do I need to keep the current or current type of retainers?
Typically on a head rebuild with aftermarket or high performance components these are no longer needed....The stock valve guide seal will be replaced with an umbrella type seal instead of the Chevrolet o-ring type making the splash shields unnecessary.
I have never re-used them after a valve spring upgrade....
