Throttle cable hookup question
Old Dec 31, 2008 | 03:59 PM
BDCMPNY's Avatar
BDCMPNY
Default Throttle cable hookup question
Happy New Year to all! I am in the process of changing the cam,carb and intake manifold. I went from stock aluminum intake to a Weiand Stealth intake manifold and a Holley 750 Carb over the stock Rochester. I have a 4spd. Trans. What have you done to convert the throttle linkage over to the Holley from the Rochester? Any help will be greatly appreciated! Thanks Marty
Old Dec 31, 2008 | 05:17 PM
Theiskell's Avatar
Theiskell
I went with a Lokar throttle cable and bracket from summit. If you decide to go this route let me know I have the part #’s.
Old Dec 31, 2008 | 07:32 PM
BDCMPNY's Avatar
BDCMPNY
Hey Theiskell, Could you give me those part numbers I will Look them up in Summit. Thanks Marty
Old Jan 1, 2009 | 10:13 AM
Theiskell's Avatar
Theiskell
The bracket is part # lokar srk-4000 check with the tech department to be sure it will work with your carburetor. If it wont they can advise you on what will.
The cable part # is lokar TC-1000HT you cut it to length, but its very easy to install. It took me about twenty minuets start to finish.
Old Jan 1, 2009 | 02:43 PM
BDCMPNY's Avatar
BDCMPNY
Thank You very much Theiskell. I will give Summit a call tomorrow. Have a good New Year. Marty
To Throttle cable hookup question
