Head bolt sealant ?
Old Jan 1, 2009 | 11:09 AM
Droshki's Avatar
Droshki
Default Head bolt sealant ?
So my short block got here finally yesterday . I am about ready to bolt the heads on. I got a new set of ARP head bolts. However after reading the pack of bolt lubricant included with them, they recommend also using ARP "PTFE based thread sealant".
1. Do I use the assembly lube in addition to a thread sealant? How do I keep them from mixing/interfering with each other?
2. Should I wait until I can get this special ARP sealant, or can I just use something like permatex blue or black and be just as good?
Old Jan 1, 2009 | 11:18 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Use Permatex 2 on the threads and use ARP assembly lube under the heads of the bolts where it makes contact with the washers
Old Jan 1, 2009 | 11:43 AM
Droshki's Avatar
Droshki
Ah-ha.....
Thank you.
Let's just file that under the "no question is too dumb to ask " category
Old Jan 1, 2009 | 12:01 PM
MotorHead's Avatar
MotorHead
Always ask when you are not sure
Others might use other thread sealant. Permatex 2 is a popular one to use because it seals real good, this is one area you do not want a leak
Old Jan 1, 2009 | 05:57 PM
gingerbreadman1977's Avatar
gingerbreadman1977
i use GM stud sealer in the tin . dip your bolt in like a knife in honey and install.
Old Jan 1, 2009 | 07:12 PM
Paul L's Avatar
Paul L
Home Depot or a local plumbing store is your friend. There is nothing magical about teflon paste.
Old Jan 1, 2009 | 08:42 PM
GlockGuy's Avatar
GlockGuy
Trick Flow recommended Permatex Aviation Form-A-Gasket sealent liquid #80019 for their aluminum heads. I used it and liked it alot. Its great for just about any oil/antifreeze sealing applicaition.
Old Jan 1, 2009 | 10:09 PM
BigBlockTank's Avatar
BigBlockTank
I've used it on every motor I've built, more than 5, less than 50,000
To Head bolt sealant ?
