hooker sidepipes removal
Old Jan 2, 2009 | 12:19 PM
MAX_STINGRAY_LT1's Avatar
MAX_STINGRAY_LT1
4th Gear
Default hooker sidepipes removal
hi everybody!!
I am an Italian owner of a '76 Vette..
..sorry for my english...it's not so good...and i wish i can correctly explain my problem...
i'd like to know how can i remove hooker sidepipes from headers..
i have tried in every way..but they seem welded ..
do you have some suggestions???
thank you so much!!!!!!!
MAX
Old Jan 2, 2009 | 12:49 PM
Droshki's Avatar
Droshki
I understand exactly what you are saying. Nothing wrong with your English.
Unless they were installed with some sort of anti-seize when put on, removing them is going to be extremely difficult.
I just went through this and ended up having to cut the headers to separate them. Luckily I was not planning on reusing them.
Perhaps you can heat them a little and then rotate the sidepipes with something like a strap wrench to get them started.
I am of course assuming that you have removed the bolts that clamp the sidepipes to the headers.
Old Jan 3, 2009 | 05:48 AM
MAX_STINGRAY_LT1
4th Gear
oh yes...i have removed the bolts...but nothing to do...
i will try to heat them but i'm cared about chroming...
thank you!!!
Old Jan 3, 2009 | 07:46 AM
63mako's Avatar
63mako
St. Jude Donor '08-'09
After removing the mounting bolts wiggle them from the back near the rear wheel. Yuo have to jerk them hard, out then in. If you think that removing them from the car is hard waot until you try to get the inserts out.
Old Jan 3, 2009 | 09:53 AM
69vettester's Avatar
69vettester
welcome, very nice looking Vette you have.
I installed my hookers and used anti sieze compound liberally. 5yrs later I wanted to use a new insert "Spiral Baffles" to compliment a new engine build. I got them separated with the "wiggle and twist" technique mentioned above. I kept the headers bolted to the heads so I could get some leverage. I got them apart after "MUCH" sweat and effort. The first one got a little lip damage in the battle. The second came off slightly better from what I learned from removing the first. It can be done without any damage..alot of sweat.
Old May 22, 2009 | 05:43 PM
MelWff's Avatar
MelWff
I just removed mine about 1/2 hour ago. A large strap wrench and liquid wrench got them most of the way off with some wiggling towards the end.
Old May 22, 2009 | 05:45 PM
MelWff's Avatar
MelWff
The inserts come out by dropping the bellowed end from a height of about 1 foot onto a thick piece of soft wood a couple of times.
To hooker sidepipes removal
