Idle speed too high
Old Jan 19, 2002 | 12:01 PM
RMS73's Avatar
RMS73
Default Idle speed too high
On my 73 L-82 TH400. It idles at 750 rpm in drive w/ about 13" Hg vac, 10deg advance and the vac disconnected from the distributor. When I put it in Park/Neutral the speed goes to 1250 rpm w/ 15" Hg vac. When the vac is connected to the dist it goes to 1400 rpm. The mixture screws on the Q-jet are about 3-1/4 turns out.
Is the speed increase at idle from 750 rpm in drive to 1200 rpm in park normal?
Roger
