Teflon Tape or Paste
Old Jan 4, 2009 | 09:22 AM
Gordonm's Avatar
Gordonm
Default Teflon Tape or Paste
When assembling fuel line and fitting in pipe threads to pumps or regulators do you use Teflon Tape or the paste in a tube. I have always used tape but have heard that pieces can come off and clog things. So do you use paste or tape? BTW these are aluminum fittings, pipe and AN on the other side. I know nothing on the AN side.
Old Jan 4, 2009 | 09:31 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I've always used compression fittings without tape or paste, never had an issue with leaks.
...Roger...'s Avatar
...Roger...
I use either one being careful not to get the tape beyond the threaded area.I don't view the teflon as a thread sealer in this case but as a lubricant for the threads so more pressure can be applied to the seat.
Old Jan 4, 2009 | 12:01 PM
Shirley1978's Avatar
Shirley1978
i used teflon for my manual shut off valve to the heater core.. but water doesnt catch fire so maybe both?
Old Jan 4, 2009 | 12:11 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
TFE Paste.
Old Jan 4, 2009 | 12:13 PM
cargo247's Avatar
cargo247
Paste, high up on the threads.
Old Jan 4, 2009 | 12:14 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I used the yellow teflon tape ( the white will disintegrate ) on a fuel pressure gauge that was not a compression fitting, and it fixed the leak.
Fuel lines should be compression fittings and if they leak they should be replaced, that said the yellow teflon tape will work, be sure not to tape all the way to the ends of the threads
Old Jan 4, 2009 | 12:50 PM
midyearvette's Avatar
midyearvette
paste
Old Jan 4, 2009 | 12:56 PM
BigBlockTank's Avatar
BigBlockTank
The yellow teflon tape is, by code, supposed to be used on LP or natural gas connections, AZ code anyway. AN fittings shouldn't need any additive to prevent leaking anyway. My tidbit
Old Jan 4, 2009 | 01:18 PM
MotorHead's Avatar
MotorHead
You did read my entire post before posting your tidbit ?
Old Jan 4, 2009 | 02:22 PM
Gordonm's Avatar
Gordonm
I agree on the compression fitting but how do you have a compression fitting on a filter when the in/out is a pipe thread. The same is on a fuel rail that has pipe threads.
Old Jan 4, 2009 | 02:27 PM
MotorHead's Avatar
MotorHead
My fuel pressure gauge had a pipe fitting, it leaked, I used the yellow teflon tape and it fixed the leak, simple as that
Old Jan 4, 2009 | 02:42 PM
baxsom's Avatar
baxsom
i have used a little paste on the carb entry lines.
every single new carb i ever put on with brand new fitting always leak without it.
AN fittings have never leaked dry but i dont want to go through the process of adapting my holley to AN fittings now that the leaks have stopped.
maybe its just me
Old Jan 4, 2009 | 02:43 PM
hgm's Avatar
hgm
Dwncchs is correct. Teflon tape is a lubricant. THat being said I use tape always starting one thread back.
Old Jan 4, 2009 | 02:54 PM
Gordonm's Avatar
Gordonm
Just put in the 2 filter fittings with tape. Kept it away from the end and trimmed off the excess. Looks good and in a few weeks I should see no leaks.
Old Jan 4, 2009 | 03:03 PM
GasketDude's Avatar
GasketDude
Have used both paste and tape on AN fittings. Preference based on application for appearance as no difference in performance. If tape wrapped correctly no issues, excess paste is easily wiped off for cleaner look. Paste is quicker.
As mentioned, each is lubricant to prevent galling of the NPT style threads. Only light oil is used on SAE o'ring AN fittings, no sealer.
Old Jan 4, 2009 | 03:20 PM
razman's Avatar
razman
a little bit of paste just as an insurance policy is a good idea IMO.......
To Teflon Tape or Paste
Old Jan 5, 2009 | 09:13 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I have been using fittings for a very long time,
Paste is generally the best option, and cleanest looking,
tape can look sloopy, and if done wrong small bits of tape,
can end up in the wrong places, " like in the carb. orffices "
Dry fittings..... try taking 1 apart after a few years,
not to mention the oppurtunity for leaks.
use the paste on the threads only, not the Ferrules. 69VETT
Old Jan 5, 2009 | 10:10 PM
BigBlockTank
My tidbit Sir, I didn't think I needed to read or ask or anything of the sort. Should I have read your post?
Old Jan 5, 2009 | 10:50 PM
MotorHead's Avatar
MotorHead
When you quote my post in your post I would assume you would have read it
