hydraulic VS Mechanical
Old Jan 5, 2009 | 05:32 PM
61LS6's Avatar
61LS6
Default hydraulic VS Mechanical
Help me decide. I am building a 406 SBC using AFR heads and Barry Grant sixshooter carbs. Should I use a mechanical or hydraulic lifters? Any other advice will be appreciated.
Thanks,
Bill
Old Jan 5, 2009 | 05:35 PM
TERRY CLARK's Avatar
TERRY CLARK
I'd go with Hydraulic !
Old Jan 5, 2009 | 06:10 PM
Gordonm's Avatar
Gordonm
Are you going to go roller or flat tappet. What is your intentions with the car. Are you going to rev the motor over 6500 rpm. Consider all these before making the choice.
Old Jan 5, 2009 | 06:27 PM
larrywalk's Avatar
larrywalk
Veteran: Marine Corps
Mechanical roller!
Old Jan 5, 2009 | 07:49 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
Originally Posted by larrywalk
Mechanical roller!
It depends on your use. I went with a hydraulic roller, rev kit and RPM limiter. Good to 6500 RPM and maintainance free with lower spring pressures for durability. If you plan on going over 6500 RPM then Solid roller is the way to go. I am not a rich man and have too much time, effort and $ in my build to rev over 6500 RPM because I don't want to take a chance of blowing it up and having to start from scratch. I have a forged 383, AFR heads, Large base custom rochester tripower and full hydraulic roller valvetrain.
Old Jan 6, 2009 | 12:45 AM
CorvetteDave01's Avatar
CorvetteDave01
If your going to run stud girdles or shaft rockers, I would go solid roller.
Old Jan 6, 2009 | 03:15 AM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Funny. I was going to say to run stud girdles or shaft rockers if you go solid roller.
Seriously, not knowing exactly what the build in question is meant for, tho I'm a solid roller fan myself, my default vote is for an HR as long as the high-revs aren't sought.
Old Jan 6, 2009 | 04:10 PM
NeverFinished's Avatar
NeverFinished
I have a 383 with a hydraulic roller and really like it. I don't have any experience with a mechanical roller. Everything I read says the hydraulic rollers have a limited life. IF that is true I know I like the hydraulic roller better.
Old Jan 6, 2009 | 07:19 PM
SmokinBBC's Avatar
SmokinBBC
Do you mean solid rollers have a limited life?
Old Jan 6, 2009 | 08:30 PM
63mako's Avatar
63mako
I think that is what he meant. Hydraulic roller cams are standard equipment in almost all pushrod engines now and have a long life expectancy with little or no maintainance. Solid roller does require periodic adjustment and inspection, stronger springs = more wear and they have lash so they impact every revolution = more wear. You will not run a solid roller 100,000 miles with no maintainance. There are millions of hydraulic roller engines with over 100,000 miles in service now that have not been touched since built. If you want to rev over 6500 RPM a solid is a must though. For a pure race engine solid roller is the way to go. If you want revs and don't mind the maintainance solid roller is the way to go. If you want dependablity, low maintainance and don't rev over 6500 anyway (most street applications) a hydraulic roller with a rev kit will fit your needs. Most HR will go to 6000 RPM without a rev kit.
Old Jan 6, 2009 | 08:35 PM
SmokinBBC's Avatar
SmokinBBC
Yep
Old Jan 7, 2009 | 02:19 PM
NeverFinished
Yes, I made a mistake. I meant Solid rollers.
To hydraulic VS Mechanical
